Wheel Spacers - AMT Motorsport - FREE SHIPPING
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
AMT Motorsport
C6 Corvette
Wheel Spacers
Sometimes only the best will do, and Wheel Spacers is one of those
times. AMT Motorsport Wheel Spacers are Milled to 0.0005 tolerance
and only weight 1.0 and 1.2 pounds each. Improve the stance and
lower the center of gravity in your C6 Corvette with a set of Hubcentric
3/4" or 1" Wheel Spacers from CCA and get FREE SHIPPING in the US
or
Choose the New 1/4" or 3/8" Spacers
AMT C6 Corvette Wheel Spacers
Regards
Chip
Hi!
I have a few questions:
1. What is the optimum spacer setup for a C6 GS/Z06 for the wheels to be almost flush to the fenders?
2. Do you do a package deal for 4 spacers, and the studs needed to use them?
Feel free to PM me!
Thanks,
Braddley
Feel free to PM me!
Thanks,
Braddley
Supporting Vendor
1/2" isn't really possible. If you go a half inch then you cover up the lip of the hub but a 1/2" thick spacer doesn't have enough material to turn a new lip. I suppose you could run a 1/2", non-hub centric spacer but I wouldn't run that on my own car, so I wasn't going to make it for others.
It is possible, barely, but can be done. I have a set.
Received 8,803 Likes
To follow up on NSF’s question from last year you recommended not going more than 1/2” without new studs. I see you now off offer 3/8”, would these give the desired appearance of the tires being flush with the fender lip (GS) without requiring new studs? Thanks.
If it were me, I would do studs on 3/8, but you can get extend lugs that
will do it.
I tend to error on the safe side of this one personally
3/8 will work pretty nice on flushing out the wheels
Regards
Chip
3/8 is the tipping point - anything larger "requires" longer studs
will do it.
Regards
Chip
will do it.
Regards
Chip
