[Z06] BTR4 cam to much for tracking
Hey guys got another question I was told a big cam is bad for track racing. Just because of the lift on the cam at high rpms puts allot of stress on the springs. and had people suggest not to go with this cam for That reason. I will track maybe once every month you think I will be fine?
Change springs every 8k miles?
Do you mean road course events by track racing?
CammedC6520 (08-14-2017)
i drove the **** out of my car every weekend on the streets of mexico and drove it every day with the 1st generation of that cam. i didnt have any issues, but i like a nasty cam.
traction out of the corners will be an issue
silver z06
silver z06
Well Auto-x is a bit different then 20 minute road course sessions but either way the BTR4 cam is more for the drag racing crowd.
CammedC6520 (08-15-2017)
silver z06
https://www.youtube.com/watch?v=9w6S...Q16qXq55Y7TXTV
silver z06
Video isn't playing for me
Its a power-band thing...BTR 4 is top end. Can you Auto-X with it? Sure. Are there better cam choices that would be far better suited towards that application? Absolutely. Will those cams leave top end HP on the table that you wish you still had at the drag strip? Yep
I'm sure you can find a happy medium out there...but I would figure out what is more important to you (Drag vs Auto-X), and lean towards the cam that best suits the majority of your intended use.
You could always have Kohle spec a cam for you if your sending your heads back to him for porting.
I'd say stick with what you have for now...you're doing all supporting mods that the BTR4 needs to shine. Porting the heads, MSD/NW combo. Those were the missing pieces to your combo. You'll probably pick up another 50 rwhp after a retune by adding those items.
Then you can make a decision about the Auto-X vs. Strip thing; because right now, you're not getting the full benefits of that cam.
You are right, I will decide to change it when I hit the 10k mile mark on the springs. I was told this setup will not last me long on stock bottom end making 580-600whp is that true. On auto x and drag and street?
Depends on use and how you treat the car. Of course running the car hard will shorten the life expectancy, but just make sure you're doing all the common sense stuff. New fluids after so many events rather than actual miles. Blend some 100 octane gas in with your crap 91 CA stuff, or at a minimum adding Torco to your fuel. Maybe even look into an Alky kit. Detonation under load is no joke on these cars...super easy to crack a sleeve or shatter a piston if your fuel isn't on point. As long as you're smart about it, it should hold up...but hey, things can and do happen.
Thanks for all the information, how do you know if detonation is happening?
That's a good option as well if you don't mind having drums of fuel at your house.
CammedC6520 (08-16-2017)
BTR Stg 4 power band is from 3500-7200
BTR Stg 3 power band is from 3000-6600
I have done a direct comparison in between the two, as a good friend of mine is running the Stg 3 cam. we both made the same power, his was just in a lower rpm range. on a 60-160 roll race we were dead even at 160.
So it all depends on where in the rpm range you will be most of the time when auto crossing.
fyi both cars were north of 600 rwhp
Yeah I made my decision full e85 I'm also milking it another .060 by ahp maybe if the power gains are worth it I don't want to fill up every two days. But what injectors should I go with? I'm looking for a decent set up but the cheapest I'm on a budget.
