opening up side cove "vents"? / wheel well high pressure area
when i was pulling the dry sump tank out of my 09, with the wheel well liner removed i notice i could see directly out of the side cove vent in the fender.
has anyone ever made this functional? im thinking about a 2" x 12" slot cut in the wheel well liner lined up with the cove vent. to help relieve the high pressure inside the wheel arch, and minimize lift.
anyone done it, or have any thoughts on it?
I think "theoretically" that should help relieve some wheelwell pressure, help with downforce, maybe help keep the brakes cooler since more air can be pushed into the area from the ducts since it is now a lower pressure zone.
I removed mine from my C5...not vented from the wheelwell but they may relieve a minor bit of underhood pressure unless I opened up the wheelwell with some sort of vent. But then, I'd have to make sure that the air had a path from the wheelwell to the vent and not trying to pressurize the engine compartment. The main reason I removed mine was to mount a quick detach charging port on the passenger side for a lithium battery. I removed the driver side just to match. I think for a street driven car that drives through a lot of rain, you have to be careful because on the passenger side of my car there are electrical components that the duct cover was protecting.
If you do remove them and vent the wheelwell, just tape a few strands of yarn inside the vent and use a GoPro type camera to see if the tufts of yarn are sticking out of the vent at speed. If they are, then it is working. Due to my limited driving talent (not a pro driver) I doubt I would be able to measure a difference in lap speeds even if my ducts are working.
My car had some small "caps" stapled at the front of the inlet I guess you could call it. It looked like the factory made it to be able to be easily made functional.
I know there is a thread about this in the general C6 forum but no evidence of anything. I think the yarn idea is brilliant.
From what I can see, doesn't the wheel liner block these side vents up completely? I can't see how it would work but I'd love to be proven wrong.
I have a made a couple of aero mods to my car but I only do them after they have been proven by someone else as I don't have much time to tinker these days. It might be a small difference but I'll take it, if it works.
So please report back!
You definitely could use that vent to help reduce pressure in the wheel well. Despite the fact that my wheel wells are vented straight up through the hood.... I still made some slots to allow more pressure to be relieved. Over the winter I plan to "port" the opening in the fender as big as it can go and then make some carbon fiber ducting to connect to the wheel well. The opening isn't that big but I do think every little bit helps.
when i was pulling the dry sump tank out of my 09, with the wheel well removed i notice i could see directly out of the side cove vent in the fender.
has anyone ever made this functional? im thinking about a 2" x 12" slot cut in the wheel well lined up with the cove vent. to help relieve the high pressure inside the wheel arch, and minimize lift.
with the wheel well liners removed you can see directly from the wheel well to the cove vents and see day light. so my thought was to cut a large slot in the liner to allow air to escape into inside the fender area and out the cove vent. my suspicions are though that the closer the cut slot is to the edge of the fender wheel arch, the less effective it will be.
to reduce the parachute effect, i would think you would want to cut the slot/hole in the liner, smaller than the area of the cove vent.
thoughts?
I won't even assume to know.
Frankly I have a hard time imagining that much air really gets in the wheels well towards the back with a wheel in there. I think you are just as likely to add drag doing this mod, as removing it.
All I have done to my '08 Z51 for Aero is:
1) World Challenge Hood
2) removed that rubber lip thing underneath
3) I built an ABS under-tray that is parallel to the ground that runs from the front fascia to somewhere around the front of the oil pan if I recall.
4) Car is lowered moderately with a bit of rake to it
These are things that are proven to work by others so I just copied although no one really builds an affordable front end under-tray for a base car so I just did it. The idea was to reduce lift at the front which is the shortcoming on the C6s, although the previous owner of my car also added a nifty little ZR1 rear spoiler that probably slightly assists with rear lift at the detriment to front end lift.
arent all c6s front breathers?
i know non z06s dont have the block off panel underneith, so they technically have rad opening to grill AND bottom. but i believe all C6s are considered front breathers.
unlike an fbody that had NO grill opening, and all air came from a large 4" air damn underneith. were definatly bottom breathers.
C5s were bottom breathers too i guess?
The base cars and the Z06 both have a big *** hole in front of the entire cooling package. And the Z06s get some additional aero help by closing up the unneeded bottom hole. It does nothing to leave that big hole open except hurt aero at high speeds and save GM $4.
This is what I did.
Yes there is build up of air pressure in the wheel wells. It comes from several places. The high pressure pushes the air out and it leaves in a dirty fashion. Going out thru the vent cleans it up some as the vent and trim becomes a vortex generator. So it alleviates some lift and some aerodynamic friction
jaredtxrx (08-25-2017)
This is what I did.
Are there any electronics or anything that may be harmed or need extra protection in the vented area?
This is what I did.
If I can verify the info you state is correct, I will be doing the same.
ApexMONSTER (02-24-2022)
I think the drivers side is pretty clean. The passenger side has the PCM in it but its up high and tight to the upper liner. And the connection is sealed. It should benefit oil cooling as well.
Cheers
I can't offer exact info to help you. But I was very interested in Aero packages and how it all worked. I did a lot of research paying close attention to F1 for diffusers and DTM for front downforce. There's theres plenty of good info about the wheel well pressure and the dirty air coming out if it. You might want to serch vortex generators to learn how they allow the air to clean itself and reduce friction.
Cheers
Cheers
If you had a choice between the two types of vents, I would say the side vent might be better for venting the engine compartment if it needs it.
