C5 Corvettes for Sale Classifieds: Used C5 Corvettes for sale as well as modified or stock Corvettes
FS: [CA] F/S 2003 C5 Z06, 6 speed, 85K miles
Old 08-19-2017, 04:06 AM
cep39
cep39's Avatar
Default [CA] F/S 2003 C5 Z06, 6 speed, 85K miles
For sale is a black 6 speed 2003 C5 Z06 Corvette, with 85K Miles on the odometer. The car is largely stock with the exception of a GM LS9 cam, a one-off four point roll bar with X-brace fabricated and installed by RPM rollbar of Portland, OR, a plasti-dipped rear bumper face, and black 18x9.5" Z06 motorsport wheels at all four corners. I have owned the car for roughly two years, and have changed the synthetic oil every 3000 miles, along with all other fluids during my ownership. Highlights on the car include:
Fresh synthetic oil (less than 500 miles ago)
Recently changed synthetic transmission fluid (less than 10000 miles ago)
Recently changed synthetic differential fluid (less than 10000 miles ago)
Recently changed high temperature power steering fluid (less than 10000 miles ago)
Recently changed high temperature brake fluid (less than 10000 miles ago)
Recently changed high temperature clutch fluid (less than 10000 miles ago)
GM LS9 camshaft
PAC valve springs
New timing chain
New harmonic balancer
New serpentine belt
New serpentine belt tensioner
New coolant overflow tank cap
New GM Performance spark plug wires
New NGK TR6 spark plugs
Stainless Steel Brake Lines
Magnaflow exhaust
Custom fabricated and installed RPM four point roller with X-brace
(4) Black 18x9.5" Z06 Motorsport wheels, 265/35/18 front tires, 275/35/18 rear tires
Column lock bypass
The car has a couple of lowlights as well:
The front tires are bald and need to be replaced
The HUD bezel is cracked
There is a roughly 1" tear in the outer bolster of the driver's seat
The wiper blades need to be replaced
The check engine light came on a few days ago due to code P0452 - evap system pressure sensor/switch low. I have ruled out the gas cap as the root of this issue, so it may be a split hose or a bad pressure sensor, but it is an emissions problem and does not affect drive ability whatsoever so I have not dug into it.
The car has a clean California title that is in my possession. Blue Book value on the car is a little over $16,200, but given the low lights, I am asking $14,500 OBO in cash or cashiers check. The car is located in Huntington Beach, CA, and I am available most nights after 6:30PM and most weekends; please call or text me at 609.314.1005 to set up a meeting. Thanks for looking.
cep39 is offline
Old 08-20-2017, 10:29 PM
cep39
cep39's Avatar
bump
cep39 is offline
Old 08-22-2017, 12:09 PM
cep39
cep39's Avatar
bump
cep39 is offline
Old 08-24-2017, 11:47 AM
cep39
cep39's Avatar
bump, price adjusted to $14,000
cep39 is offline
Old 08-29-2017, 03:42 AM
cep39
cep39's Avatar
bump
cep39 is offline
Old 08-31-2017, 07:01 PM
cep39
cep39's Avatar
bump
cep39 is offline
Old 09-06-2017, 03:20 PM
cep39
cep39's Avatar
price down to $13,500
cep39 is offline
Old 09-06-2017, 04:28 PM
C0rvetteFan
C0rvetteFan's Avatar
Default Nice
Fair deal, I like it. GLWS
C0rvetteFan is offline
Old 09-08-2017, 11:37 AM
cep39
cep39's Avatar
bump
cep39 is offline
Old 09-08-2017, 11:57 AM
jimrowe0
Banned Scam/Spammer
jimrowe0's Avatar
Originally Posted by cep39
bump
Can you comment on the condition of the exterior and interior?
jimrowe0 is offline
Old 09-08-2017, 03:51 PM
C0rvetteFan
Default SoCali
Just realized you're in SoCal.. I kinda hope you hold onto it until I can afford to buy it.
Old 09-08-2017, 04:35 PM
cep39
cep39's Avatar
The exterior is about a 7/10. It looks great from a few feet away, but there is some light oxidation starting around the roof weatherstripping and the base of the hard top. There is a ~1" by 1/4" chip in the pain in the bottom of the driver's door that has been paint-penned.
The interior is nearly perfect save for the cracked HUD bezel and the small tear in the driver's seat outer bolster.
cep39 is offline
Old 09-08-2017, 06:16 PM
AwesomeC5
AwesomeC5's Avatar
Default PM Sent
I sent you a PM with some questions.
AwesomeC5 is offline
Old 09-10-2017, 04:04 PM
C0rvetteFan
Bump for a socal z06.
Old 09-11-2017, 01:58 PM
cep39
cep39's Avatar
bump
cep39 is offline
Old 09-13-2017, 12:05 PM
cep39
cep39's Avatar
bump
cep39 is offline
Old 09-15-2017, 07:30 PM
cep39
cep39's Avatar
price reduced to $13,000, need to sell to focus on other projects
cep39 is offline
To [CA] F/S 2003 C5 Z06, 6 speed, 85K miles
Old 09-15-2017, 09:49 PM
C0rvetteFan
Default Nice Deal
I wish I could buy. Great deal. GLWS.
Old 09-17-2017, 02:23 PM
cep39
cep39's Avatar
bump
cep39 is offline
Old 09-17-2017, 07:24 PM
Alwyn678
Alwyn678's Avatar
Sweet....reminds me of the BatMobile
Alwyn678 is offline
Quick Reply: FS: [CA] F/S 2003 C5 Z06, 6 speed, 85K miles
