Do they sell a spray to get rid of mold / stinky air cabin for the C6
For some reason my C6 cabin always stinks. I replaced air cabin filter right around 5 months ago and its back to its swampy type of scent.
But it still has a wild scent coming from the ac vents.
Is there a spray that they sell to spray into the A/C system?
I was at pepboys the other day and I asked one of the servicemans, and they mentioned that they do an A/C vent cleaning service for $75.
I almost did it, but I would rather find the product and do it myself so I can at least do a few cars with it
First thing, never EVER let Pepboys work on your car unless you don't care about your car, or having to spend additional money to fix the things they break.
Second, try spraying some Lysol in the vent through the cabin air filter vent.
Pro Mechanic
Received 3,952 Likes
try the link below................. Adam's product which works quite well at elimination of odors.................
http://adamspolishes.com/shop/interi...izer-16oz.html
Received 3,087 Likes
Do they sell a spray to get rid of stinky air cabin for the C6 ?
____________________________
I don't believe they have a spray that's just made for automotive AC system stink ... But they do sell toilet paper:
Attachment 48336045
JOKE .....
Attachment 48336045
JOKE .....
theres probably some mold in the ac system leaking out of the vents, happend to me too when it got super humid. turn the fan on and put it to outside air and get some fresh air in there everytime u drive , it must be all germy in the cabin right now. NEVER PUT IT ON RECIRCULATE MODE. if that still doesnt work id say go to an ac shop and have it looked, but if the smell gets better then stick with the same routine until its fully gone.
Assuming you have confirmed that your evaporator housing drain tube is not blocked in any way then there are really only 2 ways to eliminate the excess residual moisture in the evaporator case in high humidity environments that can cause musty odors to be produced on initial startup of you air conditioning:
1. Activate the "afterblow" feature in the C6 BCM using a GM Tech2 programmer. Activation of this feature causes the BCM to turn on your A/C fans for random, brief periods of time after the engine is turned off to dry out any residual moisture left in the evaporator case that if not eliminated contribute to mold/mildew odor causing growth.
2. Manually perform the same function of the "afterblow" feature by turning off the A/C compressor, turning on RECIRCULATE and running the vent function only on high for several minutes BEFORE you arrive at your destination and turn off your motor.
Using spray-in type cleaners/disinfectants in the cabin filter intake or foaming cleaners up through the drain tube only resolve the symptoms by temporarily removing any mold or mildew the cleaners can reach. If you don't take one of the two previously mentioned steps to consistently dry out the evaporator case the resulting mold/mildew will eventually return.
Not even considering the temperature difference between cooling outside air versus recirculated air running the recirculate mode actually reduces the amount of moisture in the evaporator housing versus fresh air mode.
If you turn the A/C off 5 minutes or more Pryor to parklng the car won't that help resolve the issue? 4 years of owning a vette and I haven't experienced the stinky air issue because it's exactly what I do before pulling into the garage, turn off my A/C at least 5 minutes before I get home, or wherever it is I'm at. Gives it plenty of time to dry out thoroughly.
It gets too hot, too fast in the small passenger compartment on a hot day to turn off the a/c 5 minutes before arrival. Plus I don't want to have to remember to have to do that. Had GM dealer enable the afterblow feature for $99 and no more problem and nothing to remember - which is a good thing
I'm wondering if those who are reporting the moldy smell are running their A/C on fresh air mode instead of recirculate. I've been in Texas since '87, with the first several years down in the Houston area, have had multiple cars since then, and never had a problem with mold, but I always use recirculate mode. If any state was going to generate mold it would be a Gulf state.
Lysol has worked for me on a couple of cars that occasionally had the issue. Remove the cabin air filter and spray into the intake with the a/c on the center vents. Then switch to floor, then switch to defrost. I have typically used most of a can of Lysol when doing this. The wife's car had the issue last year when we were on vacation in September; I treated it in a motel parking lot and it has been fine since then. I find it is important to use enough Lysol and to use it in all climate control panel positions so that you get it inside all of the vent locations. While this may not a permanent solution, it is cheap and lasts a long time, at least in my experience. I am more than willing to do this occasionally.
When I worked as a mechanic at GM dealerships I frequently got customer's cars with the a/c smell problem. I used a GM recommended procedure that involved drilling a small hole upstream of the evap. core and spraying a GM aerosol cleaner (with a tube) inside the airflow to kill the bad stuff in there. It always worked, I never got a comeback. After the job was finished, the hole is plugged, I was done. This repair will NOT fix tobacco smell, or dead mice, only a new core will do.
I just did this to my 05 Silverado using 1/4 cup of white vinegar and 2 cups of water sprayed into my air intakes below the windshield. Vinegar is chemical free, Lysol is not! The vinegar smell dissipates rather quickly and seems to eliminated the smell. There are several You Tube videos on this.
Retail sales and repair shops that sell and repair air conditioners have a chemical that they spray over the coils to remove smells, might check with them. I made the mistake of talking to the girls behind the counter in the shop I went to and they wanted to sell me a gallon jug for 25 dollars that you mix 1 part to 8 parts water, way more than I would ever use. Check with a service repair person he would probably give you a small amount out of his truck. Again it is a chemical that you are spraying into your vents!
Do a search for more insights.
If AC is the issue and you DIY it is not so difficult.
Cost $40 for products.
I do say you may need to do this for months in a row to true kill and mold et al.
BG products are highly recommended.
NAPA parts also some products.
1) Foaming Cleaner...insert through AC box rubber drain tube.
2) Spray Cleaner ... insert through AC vents into the ducts.
There is a GM tech bulletin on this in which one drills into a duct, yet the drain tube access accomplishes the same IMO.
Good luck and again you may have to do this cleaning multiple weeks/ months in a row.
