FS: AMT camber kit with both front/rear upper control arm stud kit!
Sr.Random input generator
SOLD
This is the complete kit that has adjusters for all lower control arms, as well as studs for both front and rear upper control arms. I also have an extra set of shims as narrow as 1/64" for greater flexibility in alignment tuning.
When you include the front UCA studs as well, it comes to $510:
https://amtmotorsport.com/products/a...-camber-kit-c7
I am asking only $375 SHIPPED for the whole kit! I've used it for only about 500 miles. I will be testing different coilover setups, and it would be hard to do quick fixes to alignment with each coilover setup test, so I had to uninstall it.
Supporting Vendor
Sorry you don't think it's going to work for you, but I've got the same question as C5racer: seems to me you would want to keep this kit on specifically if you're going to be switching out a bunch of shocks, so why get rid of them? You should be able to just take em out, note your positions, and put them back in the same way and never have to align.
We'll be working on a new coilover setup, and I'll have to try various alignment settings. This kit is great if you'd like to lock in your settings, but it doesn't seem to be designed for minute changes.
Supporting Vendor
The changes are indeed minute with the shims on the uppers, though I'm sure you know that. The C7 takes a long time to align anyway you slice it, though it definitely takes longer with the camber kit. Good luck with whatever way you go with your setup. And that's a great price for the kit - I'm tempted to buy it back from you!
Yep, it's mine.
Haha, indeed it's a good price for anyone who need these : )
Ttt
Sold
