Cant Get My LT-4 To Start-Help!
Hey All,
Frank here. Just picked up a project LT-4 it good shape. Only thing is it sat for 6 years under a cover. Car cleaned up nice, and everything seems to work.
Except it wont start. Before attempting to fire, I Changed Serp Belt, Changed battery, had alternator checked (fine), changed fuel filter and added 5 gallons of 93 and Sea foam additive.
Before adding the gas, the car read basically empty (and only a little bad gas dripped out when changing the filter.
Now, after putting in gas it still reads empty (stuck float?).
I pulled ignition and cranked to lube with oil. Once done, I tried to fire, and it wont do anything but crank. Could it be fuel pump? How can I check? Any advice would be helpful.
I am pretty handy but not a mechanic. HELP!!
Thanks in advance,
Frank
Thanks in advance,
Frank
engine is start is basically simple, is there spark and fuel. so you need to check for spark and fuel. spark is easy enough pull a plug wire and see if it sparks to ground. be careful cos it can shock the sh*t out of you. next you need to check for fuel at the engine. this means you have to check for fuel pressure at the injectors. these are the easiest and first two things to check. from there it gets a bit more complicated. suggest you take some time and search for no start situations and educate yourself. there is a lot of good info out there.
Zen Vet Master Level VII
If you have a pressure gauge, check the fuel pressure on the rails with the Schrader valve. If you have pressure, then you need to focus on the ignition/spark side.
Now, if your fuel gauge is off you may have lost ground in your tank especially if the tank sat empty for years. The pump and fuel sending unit share the same ground.
Do you hear the fuel pump whirl/spool up when you turn the key?
Actually this is not a bad repair and should take 45ish minutes. As long as you are in there, just replace the pump, they are super cheap. You will need to take apart the fuel gauge sending unit and clean as I bet it is rusty. There are stickies on this as you need to be super careful. I did mine about a month ago, it was no big deal and it restored my gauge accuracy .
You will need to confirm you have power to the pump/sender first. Take off your gas lid and find the wire harness then check and see if there is power. If there is, you (probably) have a pump/ground issue. If not double check the relay, but since you are getting nothing from the fuel gauge my guess is that your whole unit is suspect and needs to come out.
You bought that aqua car off of Craigslist?
Seeing that mess makes me wonder about the REST of the fuel delivery, i.e., lines, fuel rail...INJECTORS.
Long term storage, or even just over winter, I've always filled the tank first before putting it in storage. No issues as yet with any of that mess!
Hey All,
Thanks in advance,
Frank
Thanks in advance,
Frank
Well, when i tried to fire-guess what-nothing. It cranked and cranked- and I got a fuel reading and pressure at the rails-but nothing.
Whats the next step in the process here that you would recommend I look into. When my wife gets home from work, I will see about spark at the plugs-but anything else I should check? Stumped!
Hey all, new sending unit and fuel pump installed-thanks for all your advice.
im not sure if its the same for the Lt4/Lt1 but probably.
you could also test for spark. but the way i do it, i usually rule out one of the three before moving onto the 2nd and 3rd in the fuel spark compression trifecta!
I would be willing to bet that the injectors are clogged. After sitting for that long with ethanol in the lines at a minimum they need to be pulled in cleaned. I would go ahead and replace them.
have you tried starting it with starter fluid? I know it's not designed for gas engines but that will at least let you know if you have spark or not.
btw op, can you post some pics of inside and out with all the good and bad?
ive been wanting an lt4 project so ill be following yours.
cheers.
cheers.
starting fluid is fine for gas engines, (get you some and spray a nice fat dose in the throttle body via the PCV hose barb)
if it in fact fires on starting fluid, than the noid light determines whether or not the injectors are enabled
search google "C4 corvette fuel enable" CCM or central control module might be good reading as well. good luck with it
Any advise on which to buy? without breaking the bank? Install tips?
Frank
https://fuelinjectorconnection.com
They are local too. Might be able to swing by and get what you need.
100% what silver said.
ONE thing you might want to do before ordering the injectors is the noid light. they may well not even be recieving the energizing command.
