Who has installed Extreme Dimensions fender flares?
I'm Batman..
Pro Mechanic
Im considering ordering a set of fender flares from Extreme Dimensions (they are a forum vendor) for my C7. Im looking for a few first hand reviews so if you have them, please chime in! Here is a link to them:
http://extremedimensions.com/2014-20...s-4-Piece.html
I'd prefer not to get into a discussion of "those are ugly" or "just do a widebody kit" so I kindly ask we stick to only info/reviews about the flares.
Thanks!
Ant 🐜
Thanks!
Ant 🐜
BrunoTheMellow (09-03-2017)
I can't give you a first-hand review since I was only aware of this product from your post. However, it looks like a nice, cost-effective solution to adding a little more tire to narrow-body C7s.
The computer-generated images on the website look good, but it would be nice to see real-world pictures of them mounted on a car with wider wheels and tires that fit the flares.
Avanti (03-15-2018)
I'm Batman..
Pro Mechanic
I would like to see actual pictures as well. Wonder if the front ones could be a replacement for the spats and splash guards on my Grand Sport? Might look nice painted Carbon Flash.
wow these actually look really nice. They extend where the body line is, unlike the crap put on the Z06 and GS. Would be perfect for using with the 18x10.5 c5 z06 wheels for track days.
https://www.corvetteforum.com/forums...post1587048065
I'm Batman..
Pro Mechanic
I may be doing the CF ones actually. Im in talks with Quik Z06 to order a set..
I can't speak for this product but I just got the RPI front fender "spats" in Blade Silver to match my car's paint and replace the plain black ones for the front of my GS.
I'll be installing them this week.
They may make rear flares - I don't know.
I put two links in this post.
I can highly recommend RPI - also a forum vendor
https://www.rpidesigns.com/shop/sear...s&search=spats
https://www.rpidesigns.com/shop/category.aspx?catid=317
I'm Batman..
Pro Mechanic
No, unfortunately my garage is regularly like 100+ degrees. Was quite the challenge when doing the full motor build a few months back..
I think they would be a great solution for replacing the OEM "afterthought" ones
Exactly. Because they use the body line they look very clean. By using these you extend the fenders an extra inch so you can run Z06 wheels on a Z51 and it will look fine. Those are 12" wide
I'm Batman..
Pro Mechanic
my worry would be that you'd have to raise the car quite a bit to not smash the tire onto the fender lip on dips or high G turns. Idk how the front z06/GS fenders are capable of achieving full compression with the wider rubber. The spats only keep the tire from protruding, not widen the outer fender lip. Does the suspension travel angle the top of the tires that far inward that they don't hit the lip? Guess the rear lip would be much more susceptible to getting hit since those are actually widened on the z06/GS
Thanks!
Ant 🐜
Thanks!
Ant 🐜
Can't speak about these specifically, but what I can tell you is:
I've known of ED for a very long time, and they are known for making cheap, ill-fitting FRP products that typically require quite a bit of work (sanding etc) to get them to fit.
This may not be a big deal to you, and/or this specific product may fit ok... I just want to share my experience with the company overall as a heads up.
I'm Batman..
Pro Mechanic
Same issues from what I've seen, doesn't matter whether it's FRP or CF, the parts typically come from the same molds.
They are a step below Seibon imho and Seibon isn't THAT great. They started up in Cali back in the days when import scene was hot and were known for cheap and ill fitting products. You paid a low price, but ended up paying more to your body shop to make them fit. They were on the bottom of the totem pole.
That being said, we are talking 9+ years ago, but I don't think things have changed much. Who knows, maybe they have started doing more front end fittment testing and are using more accurate molds. Couldn't say.
Me, I wouldn't purchase from them. APR is an example of a good brand that does the due dilligence to ensure fittment before sending to market.
I'm Batman..
Pro Mechanic
