Out of Warranty 2010 Grand Sport Problems
I have a 2010 Grand Sport with 28k miles. I recently had my last free oil change under the GM certified car program. On the way home my traction control light comes on (about a block away) and then the engine starts running extremely rough. Code says MAP sensor. I replace it with no change. It was making all kinds of wierd noises as I barely pulled in the driveway. Long story short, no compression on #6. HAS ANYONE had any luck dealing with GM when their car was out of warranty?
Received 2,683 Likes
2018 C6 of Year Finalist
Received 2,093 Likes
Remove your fuel rail covers and check for a plug wire off at the coil. I had the same issue. Number 7 cylinder wire had come off.
Received 1,636 Likes
I agree with the posts above. It should be an easy fix of reattaching spark plug wire.
If you have no compression then it's not a plug wire. Did you verify via a compression test or are you just throwing out a term you heard?
- reattach plug wire....free
- no compression...$$$$
Received 1,675 Likes
My 10 Grand Sport blew the motor with 34,000 so I feel your pain. GM offered nothing but an apology!
Yes, I got a GM crate motor. It was the bearings let the crank move forward and grind into the block. I asked to see it but they had crated up the old motor and wouldn't open it back up so I really don't know.
Not So Fast (09-03-2017)
Very rare to have compression just "go out" while driving with no prior symptoms. If it is a lack of compression, id suspect you ingested something thats leaving a valve open..or a valve spring/rocker arm is broken. Especially if you didnt hear any catastrophic noises prior. Check the plug wires as previously suggested. Pull a plug, see if theres metal deposits on it.. Pull the valve cover, see if there are broken springs or rocker arms.
So if I understand the op correctly, He had an oil change done at the dealership & on the way home from that dealership about a block away the engine fails for apparently no reason !! ...HMMMM ... something the dealership did or failed to do possibly ?? hard to believe that a LS3 engine just fails like that.....
wow, i missed that. Yeah, very rare if its "coincidence". Some tech forgot to add oil? Dont know why it wouldnt throw a low oil pressure light if that was the case though...
