Is an L48 worth adding performance?
I have a 1978 SA with an L48 and a 4 speed.
I'm wondering if I should add the usual intake, exhaust, heads and cam or is it worth it?
My car needs an interior and paint and I will probably not have it very long. I want to correct the problems and hopefully someday trade up to a chrome bumper car.
I guess I'm asking, is it worth adding performance to a 2 bolt main L48 and make it perform better? Or should I leave it stock?
Which will have more value when I sell it? A performance motor or a stock motor?
I know I'll have more fun if it performs better and I guess if I keep all the parts they can always be put back on and make it stock again.
Just looking for opinions.
So if you don't plan to keep it long I wouldn't plan to put a lot into it.
That said - it's still possible to get some good power gains with some decent $$. That's where I'm at now - looking for my best bang for the buck in heads, header, cam and such.
Ok
You can make several performance improvements on the cheap. These are 1st things I did
Recurve the distributor, tune it, my carb needed rebuild
21/2" exhaust low flow mufflers, then get a set back timing light, adjust timing until it runs better.
Then drive the wheels off until another comes along.
A dollar buys a lot more 78 than it buys chrome bumper,
Then you say you dont wanna keep the 78 and its not pristine,
Its a desirible project car to some with the 4 speed, how much you want for it?
Imho, hopping it up will only increase driving fun for you and might get a wider group of interested buyers as this such car likely will be a resto mod not a ncrs champ....
If you decided to (or had to) sell the car tomorrow, fixing deficiencies in paint, interior and mechanical issues, will sell the car quicker (more money) than adding mods will. That assumes the car is otherwise currently running fine.
Bottom line is, based on your initial statements, I would work on the things that will help sell the car, rather than spend money on things that are currently performing as designed.
Good luck... GUSTO
Good luck... GUSTO
2 or 4
My advice is pull the intake and get a better performance one at least....it will increase power and fun quite a bit. If your so inclined, pop the heads off and port match them to the new intake gasgets, then port match the intake to gasgets as well....the gain in power alone will help sell the car for sure!!! Other then the price of intake, its a cheap, great power gain!!! All you need is a decent drill or dremel with a couple good grinding bits. Check youtube, lots of good how to videos.
Its a 350 SB. The skys the limit. How much $$ you want to spend?
Received 1,875 Likes
2017 C2 of Year Finalist
An L-48 is a basic small block Chevy. It will respond well to performance mods.
Get the right heads to kick compression up, add a cam, intake carb and you can easily have 400+ HP. If you decide to upgrade shortblock later you can transfer all your parts.
JIM
JIM
The only down side is that the 78 Base engine L-48 was coupled with a Saginaw wide ratio 4 speed in 78/79 which is not known for its durability. Even at 400 GROSS HP, that Saginaw 4 speed will need some loving to avoid grenading which it will under moderate abuse.
The 78/79 L-82 4 speeds that were close ratios were Borg Warner Super T-10's, much better than the Saginaws but still not super durable above 400-450 Gross HP....
Some solid tuning, with a recurved distrib, properly functioning carb and free flow exhaust will help. It is always impressive to a buyer when a cars starts instantly runs really well and pulls hard.
If it where mine I'd do the above, plus a used aluminum L82 intake, some nice valve covers, chrome air cleaner and MC lids. A strong detail/tidy up under hood and it will look sharp when you pop the hood.
Also on my list would be a new timing chain and a decent mild cam. It will transform the driving experience and sound good.
A lot of this stuff can be picked up cheap and or used. If you can do this yourself you are probably in it for $500-600 for parts fluids, gaskets etc.
It's a Corvette and most buyers are in it for the dream, so aside from being clean it should be able to move a bit
Even the non mechanically knowledgeable value the care shown by a clean, sharp under hood appearance.
You might not realize a 100% return on your investment but you should get more than half back and the car will be much more satisfying to drive and own, even if you just keep it a year.
Just my thoughts
Just my thoughts
I will say if you're going to sell it anyway...why bother? It's not going to be a high end collector car anytime soon. Clean it up and make it a nice car instead of spending $$$ on hot rod parts that you're going to sell anyway.
JIM
JIM
Received 3,043 Likes
St. Jude Donor '05
youll never see one penny back on engine mods ;just detail it, fix any leaks & get it running good.
on the other hand if power is something you want while you own it then just do it. Why own a car you hate driving?
Theres just as many buyers for a modded one as a stocker.
Some will have you think that ALL buyers will only take a stock perfect one, that is bs.
Either way the buyer is going to chisel you on something lol
I could not agree more! When folks ask me why I spent $6K to upgrade/rebuild my L-82, I always preface my comments that I did it my way not because of any investment thoughts but simply to have the car the way I wanted it....Cars in general are a bad investment. Do it for the love of the car and your enjoyment.
Thanks for all the thoughts and suggestions. Still not sure what to do.
I'm leaning towards fixing all the cosmetics and getting her running great as stock. Money best spent in looking good I think. Then depending on how it comes out, I may do some modest mods just because it will be more fun when I push the pedal.
The car is sound. Needs an interior and a paint job.
Any guesses what it's worth? I have a number in my head but I'm curious what you guys think.
Just my thoughts
Just my thoughts
It wouldn't count on it going up in value too soon, but by fixing all the little things wrong, tuning it up as previously mentioned, and cleaning and detailing the car will add a little value. Then sell it and move up.
I used to buy old cars that were solid basically but needed a little TLC and after fixing the little things old cars usually need and cleaning really good, I would sell them for a good profit.
Mike
Mike
As far as increasing in value over the next two - three years, if the over all condition of the car improves, chances are pretty good it's value will increase, ...at least some.
Good luck... GUSTO
I believe in 78 the horsepower difference was only 20+ between the l48 and l82, BUT if you can find a cheap alluminum intake and port it then you could almost increase HP by 25-30 percent, match that with a decent working carb and you will be close to 300 ponies providing the engine is healthy.
