dual-mode exhaust not opening
2013 grand sport,took fuse out exhaust still wont open at 3500 rpm. engine off normal (open).start engine they close(normal). thanks for any help.
You have a vacuum leak obviously, try to see if the hose is still connected to the back of the intake, very hard to see. Some of us had the plastic bend crack where it goes into the firewall. There is a solenoid behind the passengers side tail lights that also goes bad. Those are the most common although the hose on the back.of the intake seems to only occur if the intake was recently off.
silver2013, from your original post you said:
If you took out the correct fuse, or if it blew, those valves should just stay open.
- when the motor is NOT running, the NPP valves are Open
- when the motor IS running, the NPP valves are Closed
When my solenoid went out my symptoms were strange to me. Upon start up my exhaust worked normally. Valves either open or closed dependent on where I left the mild to wild set. They would be normal until I either opened the valves by the switch or RPM. At that point they would not close. Turn off car and when I started it it would again start to work normally. Until they opened as they should.
It failed in the 'valves closed' position. Valves open when car off, fully closed when running (engine vacuum applied), blown fuse due to internal short.
No outward signs the valve was damaged or melted as some have experienced.
