Breaking up above 4k rpm ?
05 t-trim blower,meth,boosta pump,585whp. Car has been sitting in garage for a couple months....took it out for a spin tonight and is breaking up/bucking above 4k under boost.....where to start? Fuel pressure? Do the boosta pumps generally just give out w/o warning? Drives fine out of boost....
Plugs have maybe 300 miles on them (but will re-check),checked hobbs switch and injector wires too. Best way to check for vacuum leaks? Runs perfect below 4k rpm....
Smoke test, windex, soapy water, etc.
Pressurize intake and watch for bubbles as you spray connections with soapy water.
^ Sorry to say but mine was the same thing. It eventually bent a valve and kissed the piston. Mine was due to a shitty shop install and not measuring pushrod length + I used PAC dual springs, now I use BTR dual springs.
Dealripper (10-10-2017)
Well I hear you saying the plugs only have 300 miles and while I agree that they should last longer on you particular setup. I have found that they tend to fuel foul quicker on the FI setups. Running fairly rich under boost most for protection etc... Unless your running an IR plug Its a cheap $25 fix to put some new NGK plugs in it instead of "Checking them" you've done half the work to pull them. Then you stick them back in and the miss is still there, and you do a bunch of other checks to find out later that it was plugs to begin with. So I agree to start them but just replace them and move on to the next potential culprit. GL!
Okay. Let me know if it is your BAP I have one with 3 track passes I'm trying to get rid of, even then if you're gonna do a fuel system like ecs or A&A shoot me a PM as well.. I have some info you might want
