C3 Parts for Sale/Wanted C3 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket
FS: 1975 Misc Parts
Old 09-14-2017, 03:24 AM
70s Vette Guy
Support Corvetteforum!
70s Vette Guy's Avatar
Default 1975 Misc Parts
I have a 1975 that I bought as a donor car.
Selling the parts I won't be using.
I have a 1975 Corvette with passenger fender and door damage. The car wasn't hit hard, but I bought it as a donor car for another project of mine. I will be selling all the remaining parts off of it. Many parts are new on the car.
Headlight system complete from switch to popups - $700
Steering column tilt/telescoping complete with steering wheel, button and keys - $700
Dash pad drivers $150
Gauge Cluster including, all gauges, bezel $200
Front Headlight Area and Right Damaged Fender, include inner fender $200
Rear Clip - $400
Tail Lights set of four $100
Bird Cage and Fire Wall (no rust) $500
Complete Suspension - Rear Trailing Arms Including Brackets and Rotors, Front Upper and Lower Control Arms, Sway Bar and Front Axle Assemblies Including Brackets and Rotors - $700
Complete Power Steering - Power Steering Unit, Valve, Cylinder, Linkage and Hoses - $300
Front Bumper Reinforcement System $250
Front Spindles, Knuckles, Rotor & Calipers - Complete - $200 each side
Radiator w/auto trans - $150
Radiator Support - $150
Drive Shaft w/U-joints - $75
Auto Transmission Driveshaft Yoke - $70
Upper and Lower Control Arms - $200 each side
Trailing Arms - $200 each side
Front Springs - $40 pair
Front Sway Bar w/hardware $75
Steering Box - $125
Side Lights (set of four) - $65
Wire Harness - Engine, Dash and Rear - $200 for all three
Seat Belt Covers - $70 Pair
Kick Plates with Speakers - $50 pair
Steering Column Lower Cover - $40
Rear Window -$40
Lots of other parts - just ask.
I will be posting more parts as I go through them.
Keeping frame, engine, windshield, carpet, misc. interior pieces, spare tub and A/C.
Thanks
Hood $100 - Sold
Hood latches, hinges, cables - $125
Left fender sold
Diver's Door w/power window $250
Seat Belt Reinforcements Both Left and Right $60 Shipped in lower 48. Sold
Tilt/Telescopic Steering Column with steering wheel and button - $700
Driver's dash pad - $150
Speedometer - $100
Center gauge cluster with all gauges, clock not working - $200
Please note there is a small crack on one of the red side lights. Also one of the red side lights has a metal backing.
Old 09-14-2017, 07:16 AM
Tom Larsen
Tom Larsen's Avatar
Hood $100
Front Clip - $500
Diver's Door w/power window $500
Tilt/Telescopic Steering Column with steering wheel and button - $900
Driver's dash pad - $200
Tach - $125
Speedometer - $100
Center gauge cluster with all gauges, clock not working - $250
PM sent
Old 10-17-2017, 07:18 PM
70s Vette Guy
Default 1975 Misc Parts, Updated Pricing and Additional Parts Offered
Updated Pricing and new listing of parts for sale.
Old 10-17-2017, 09:24 PM
Tewski
Tewski's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'23-'24
What's the code on the differential?
Thanks
Old 10-17-2017, 10:14 PM
John 65
John 65's Avatar
Default 75 tops
Are the t tops for sale? They look different. John
Old 10-18-2017, 12:58 AM
70s Vette Guy
Default code
Thanks
The only number I can see is on the cover - 3871375. If you want another location I will have to pull it out this weekend. Let me know.
Thanks,
Jim
Old 10-18-2017, 01:00 AM
70s Vette Guy
Default Tops
Sorry the glass tops were already sold.
Old 10-18-2017, 08:04 AM
Tewski
Tewski's Avatar
Thanks,
Jim
Hi, looking for a two letter code, such as
AA
AB
AC
AY
AW
AX
LR
The code is stamped into the differential case.
Thanks
Old 10-18-2017, 12:17 PM
Vetteaddiction
Vetteaddiction's Avatar
AA
AB
AC
AY
AW
AX
LR
Thanks
Jim
It's right at the bottom, on the flat surface. You might need a toothbrush and some simple green to uncover it
70s Vette Guy (10-19-2017)
Old 10-18-2017, 09:12 PM
70s Vette Guy
Originally Posted by Vetteaddiction
Jim
The code is A W W 1 9 9
I did verify that it is a 3.08 by watching the number of u-joint turns to one wheel rotation.
Hope this helps.
Thanks,
Jim
Old 10-18-2017, 11:02 PM
bmans vette
bmans vette's Avatar
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Good luck with your project.
Good luck with your sales.
Like your color........guess why?
My project #1 Racer will keep the yellow but add black accents and stripes.
Bman
Old 10-19-2017, 09:03 AM
Vetteaddiction
Just got a hood from Jim shipped through Greyhound. Got to me in 5 days coast to coast. Great price, super packing, nice condition.
Excellent transaction, I highly recommend doing business with him.
Old 10-19-2017, 10:20 AM
bmans vette
Good news.
And yes Greyhound shipping is really cheap and good compared to the other 3 major shippers.
I had a stinger hood come to GA from CA years ago and had the same experience. I think it only cost me $75 shipping.
OP sounds like a good guy to do business with...
Old 11-07-2017, 03:32 PM
Redvette_22
Redvette_22's Avatar
Jim, thanks for the hood lock assy, it was better then you described
I'd like to know if the two seat belt reinforcements are still available?
Old 11-07-2017, 07:09 PM
glinares
glinares's Avatar
How much for both rocker moldings and associated hardware?
Thanks,
George
Old 11-07-2017, 09:07 PM
70s Vette Guy
Default Seat Belt Reinforcements
I am in the process of pulling the body off the frame this weekend. My plan is to remove the reinforcements and post pictures. Someone else has been waiting for me to pull them off, his only concern is one of the pictures looks like either the reinforcement was modified or the fiberglass on the car was modified. Won't know for sure till I pull it off. I'll keep you posted.
Thanks and I'm glad you were happy with the driver's hinge.
Old 11-07-2017, 09:10 PM
70s Vette Guy
Default Rocker Moldings
Thanks,
George
I do still have them, $125 for the pair.
To 1975 Misc Parts
Old 11-08-2017, 08:34 AM
Tex75Vette
7th Gear
Tex75Vette's Avatar
Hi, Ive got a 75 yellow L48 vette just like your donor. I'm needing a left frt fender, hood and transmission. It looks like I'm to late for the hood. Do you still have the transmission? Is it the correct code (original) for the car? CK hopefully? Would you be welling to sell the left frt fender and how much? Thanks, Kevin
Old 11-08-2017, 04:45 PM
70s Vette Guy
Sent pm
Old 11-09-2017, 12:45 AM
adc103
adc103's Avatar
Is the black carpet in good condition? Would you be willing to rip it out and sell it? Also what about the center console cover, the one that covers the hand brake?
Quick Reply: FS: 1975 Misc Parts
