Getting my Z06 to 1000 hp !
Aaron who use to work at the old Borelli doing the work.
Please LET ME KNOW if I am screwing up or MISSED ANYTHING !!!!!!!!!!!!
Received 1,817 Likes
Reading the invoice, it looks like they used a factory fuel lobe for the high-pressure side. A true 1000 horsepower is pretty much unheard of, without doing lots more, like supplemental fuel injection way beyond what the factory high-pressure side can do.
but how does everything look ? Are there any holes or anything I forgot ?
I did everything you did plus 2" ARH, 38 Fuel Lobe Cam with racing lifters, overdrive pulley, Akrapovic full exhaust, 30% Increased Fuel Injectors to feed "FULL E85" with additional tank and pump.
I got 720 RWHP on a conservative dyno at Katech.
BTW Power loss from the crank is as follows:
10% Manual
20% 8 Speed Auto
chevyfanatic (09-18-2017)
EXACTLY !!!
10% Manual
20% 8 Speed Auto
10% Manual
20% 8 Speed Auto
I see your going with a TSP SV cam so I take it you have an A8? Your going to shell the TC pretty quick at those numbers (which I question the setup will even make). You're also taking a big chance with the stock pistons.
Really ?? you mean the A8 TC ? I need to add new CLUTCH PACKS or ???
Now you have me SCARED !
But I dont do BURNOUTS
I hope that the shop you have talked to hasn't told you that the combination of parts on that invoice will make 1000 BHP or anywhere near. If they have, RUN!!!
chevyfanatic (09-19-2017)
Supporting Vendor
no pain at all just come over to az and let us set it all up and do the car
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
The following 4 users liked this post by WuTang:
almost a grand for an expansion tank holy crap. Fasterproms is only 500 via attached link
https://www.texas-speed.com/p-4946-f...vette-z06.aspx
No way in hell is this making anywhere close to 1000 crank hp.
Also if you ever plan on adding a pulley you wont be able to run e85 with stock fuel lobe, even a blend.
