Which Shift Knob Cap...
Which Shift **** Cap...
I am by no means a master customizer. I typically mess things up before I have an expert do it, but I decided to customize the shift **** caps I had. I have 2.
Which one looks better:
Or #2
Or #2
Just an observation, but why can't folks take pics & post them so they are in correct orientation (happens alot on here)? Now back to the show, I prefer the thinner black lined **** & very good job on both!
Well, honestly, from my pov, they are all in the correct orientation. Mine must display differently than yours because all six pictures are displayed in the orientation you would see it with 1,3,5,7 at top and 2,4,6,R at the bottom. Do you see something different?
Received 3,096 Likes
Finalist 2020 C7 of the Year -- Unmodified
First pictures with the thinner lines looks way better.
Turn 12!
Stock
Received 1,817 Likes
As long as you can do whatever you want, you should print the shift pattern backwards, to confuse car thieves.
Thank you. I looked on my computer and the same problem. I uploaded them via my ipad and just looked again on my ipad and they are all upright and look normal....who knows...
bapd77 (09-21-2017)
You have to get a thin pry tool underneath it and push fairly hard to pop it off. It takes quite a bit of power to pop it off, almost feels like its going to break. But it comes off fairly easily once you figure out how it is done. I'd suggest one getting the bottom end up slightly, do the top and it should come straight off.
WzUpDoc (09-21-2017)
