Cell phone wedged inside infotainment storage comprtment
1/4 inch opening should be enough to take a stiff wire, like coat hanger, and try to hook it or push into a different position.
If that doesn't work, hang car by rear bumper and tap on the compartment door.
Still no luck, get a new cell phone.
Received 3,818 Likes
Dealer should charge about $300 to take it apart and put back together. Rick Conti had a video on this a few wees ago about a guy who had a stuck handgun.
tkgreer (09-21-2017)
If it is on vibrate, call it. Might vibrate loose.
Excellent.
Also find a safe place where you can do high-G turns to right, to left, and zigzagging right to left. You should be able to get close to 1 G on braking and turning, and there's a good chance that will jar loose your phone.
Good luck.
PS: Hanging the car by the back bumper wouldn't produce any more G force than a panic stop, so don't bother.
Good luck!
Garbud
Wow! Had the same issue one month ago when my cell phone lodged against the screen. I fooled around with a wire hanger for about an hour before I drove the car to the dealer for help. The tech took the car into the service area and dislodged the phone within ten minutes. What a relief!! I was told that the only way to get into the compartment was by taking dash down.
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
PROOF: That is what caused the cup insert to dump a full water bottle in my September 2013 built C7 soon after I got it! The insert tilts! Since, have removed the 3/32 inch thick rubber inert in the recess (it just pulls out) and glued the insert to the base! Water bottle holds in 1 "g" turn and well past a 1 "g" Stop! Made that mod in my Grand Sport as well!
Go Canes!
I got my Glock 43 stuck in there. I had to use a couple of screwdrivers to prop it up and was finally able to open it. I won't be doing that again any time soon.
Received 1,762 Likes
It don't even take a good hour to pull it all apart not bad at all if you have the DIY that is in here on pulling it all apart.
Received 2,051 Likes
St. Jude Donor '13
4thC4at60 (09-30-2017)
I am almost done with the z51 to a z06 body panels on the car will post some pic's as soon as I am done should be done by this next week. Robert
Received 5,217 Likes
Sheesh... seems there is a lesson here for all, given the number of reported incidences. Thankis for the heads-up, guys!!!
I no longer put much of anything in the "nifty" compartment. My phone got stuck the first day I had the car which of course freaked me out. After 30 minutes of fidgeting with a coat hanger, I finally got it out, but don't want to go through that again.
