Snow tires
Welcome to the family!
Maxpowers (09-21-2017)
Received 2,051 Likes
St. Jude Donor '13
But the Michelin site sometimes has sections that contradict each other, can you post a link to where they claim to have the widebody AS or snow tires?
And how are they during fall/spring or do you exclusively use during winter?
Thanks!
I run them from around mid-October to May 1. We can get surprise snow that early and that late in the season. They are ok on bare and dry roads but I'm certain all-seasons would be better if I didn't need/want them so I can drive on the snow. I have a truck for the sloppy days. My paint is still perfect after two winters of choosing my driving days wisely; some of the most fun I've had is in a fresh snowfall.
tsoed (09-21-2017)
Acct suspended by request 30 April 2019
There isn't a perfect solution for the rear tires on the GS or Z. I am researching it as well. The web site below has a lot of good info on tires.
https://tiresize.com/tiresizes/335-25R20.htm
You might want to define the snow driving mission - the wide tires and relatively light weight of a C7 coupled with not a lot of ground clearance will make driving in any snow that is wet and heavy pretty tough; probably not too bad in the powdery stuff.
OK, there are exactly zero snow tires. There are several all season tires available for the base and Z51. But make no mistake, they are NOT snow tires. They work when the temp gets cold, they will work on very light packed snow or slush. But they are not, nor do you want to be out in, real snow with them on a C7.
And I have no idea about sizes for the GS/Z06.
A fwd Carola on real snow tires would make mincemeat of a C7 in snow.
Received 2,371 Likes
The Very Best for Snow
S. Arizona
The following 2 users liked this post by Woodson:
deagonkennels (09-22-2017),
UsernameProtected (10-01-2017)
St. Jude Donor '13
And of course the AS3+ All Season.
Here's a pic of our C6 when we got up after a night of snow in central Illinois. The roof was clean when we stopped last night, so you can see how much snow fell while the car was parked. We made it through about 50 yds of virgin snow to get out of the parking lot. On those horrid All-Season tires. I wouldn't intentionally get into that situation, but the forecast was wildly inaccurate and we had little choice.
A Corola also beats a Corvette when you need to carry four people, but that's not the point.
VNAMVET (09-30-2017)
For the limited and accidental snow driving I will do with my 2015 Z-51, I opted to put Michelin AS 3+ ZPs on.... am running them year around. Snow tires per se....NO.... but they will work in cold weather and the risky days I decide to venture out in during Winter months.... and they are ZP .... just in case!!! I find the ride and street/highway handling to be fine.... far quiter than PSS factory tires and more versatile in other than perfect/dry conditions.
Of note, Costco carries them (order online, free ship to store) and they did a flawless job mounting them.... nitrogen and all!!...LK
I just looked on the Michelin website and Tire rack website, neither of them show any kind of AS or winter tire for the C7 GS/Z06.
