Z06 RPM overrun
I'm pretty sure they are programmed that way, to make it easier to shift into the next gear...My M7 does the same thing...I'm sure someone else can give you the 'official' reasoning...but I don't find it to be dangerous at all. I like it.
In your mind it might feel like 2 seconds. In reality it is a split second at most. I haven't had a problem with it in over 2 years on my 2016 A8,
Really? I haven't noticed it, and that was one of my big problems with the twin-turbo Mercedes I had: you'd lift the throttle and the engine would lift about a second later, very disconcerting with 600+hp.
Which drive mode where you in? If you were in "Sport", I believe you were noticing the effects of PAL (Performance Algorithm Liftfoot). If you were in "Track", then I believe it's the effects of PAS (Performance Algorithm Shift). See the "Driver Mode Control" section in the "Ride Control Systems" section of the Owners Manual. This is on Page 197 of the 2016 Owners Manual.
Bill B.
Bill B.
crmcar (09-21-2017)
crmcar (09-21-2017)
4th Gear
Bill B.
Bill B.
Received 1,817 Likes
When the car is under boost, you have a large volume of pressurized air trapped between the rotors and the intake valves. When you let of the gas, all that air is still pressurized(even though the bypass valve opens and that does drop the psi a little). It takes a short second for the engine to use that trapped pressurized air, and settle back to ambient air pressure to feed the engine that is regulated by the throttle body.
Platinum Supporting Vendor
Big negative numbers in the upper right hand corner of the Driver Demand tables took care of it.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
