Missing numbers
Missing numbers
Hi all. I have a friend with a 61 that has a 283. The numbers match on the car but the engine numbers are missing. He said he believes it has the letters F and O stamped and where the numbers should be it is blank.
any thoughts??
thanks
any thoughts??
thanks
An intertying thought, the numbers match on the car but are missing? As good a definition of matching numbers as I suspect you will find.
vettebuyer6369 (09-22-2017)
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Over the counter replacement block.
Roger Walling (09-24-2017)
The block was probably decked, removing most of the letters/numbers on the pad.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,321 Likes
Received 6,929 Likes
2015 C2 of Year Finalist
When an engine is rebuilt completely many times the top surface of the cylinder decks are milled off to ensure a flat surface and a good seal with the heads. The block deck surface is at the same level as the stamp pad., so when an engine is decked the stamp pad numbers are removed as well.
Some others on the forum would rather be snarky then give a positive response.
Thanks again
Next time, read your post before you submit it and make sure it says what you mean.
