I stripped or broke bolt A/C tensioner
I was replacing belts and decided to pop the seals and add grease in the 4 pullies.
Tighting the last one, the pulley for the tensioner, it just went loose like the bolt broke.
I think the aluminum threads stripped.
Can the threads be fixed or time to buy a new A/C tensioner?
Helicoil?
1/4 mile/AutoX
Helicoil !!! the wonder fix !!!!!
Helicoil?
I took a break and left the car/tensioner alone.
Came back and removed the whole tensioner assembly, the threads are weak in the middle of the hole.
Put the bolt in it again and it is getting pretty tight, however that is with me holding it on the top of my trash can while tighting with ratchet.
It may be ok, but just in case, I have a idea.
Tomorrow go to hardware store and try to find a longer bolt and a lock nut to secure it as a backup if the threads let loose.
That is if the nut will fit in the area on the back.
1/4 mile/AutoX
I added some high temp grease to mine 5000 miles ago, no issues !!!!
Received 1,261 Likes
why not just buy a new tensioner?... they are cheap enough and you are already there anyway
1/4 mile/AutoX
1/4 mile/AutoX
Wheel bearings turn at 1400 RPM at 100 mph. The small tensioner pulley can turn 14000 RPM at that speed. I didn't make this up. Evil Twin, a designer of the C5 explained it many times why the pulley should be replaced instead of greased.. I believe him.
SG Lou (02-16-2018)
1/4 mile/AutoX
and you know for sure the replacements have the right grease and amount ????? engineers also designed the rocking seats, column lock issue, vibration damper failure, and many more !!!!! ??????
big difference between an engineer and someone who has to actually work on the stuff
Pounder (09-22-2017)
1/4 mile/AutoX
