FS: Cleaning the garage, raising funds for paint!!
I'm clearing out the garage and getting rid of some parts to get money together for paint.
I have a set of 15x8 Rally wheels with BF Goodrich Radial T/A tires size P255/60R15. The tires probably have less than 100 miles on them, still has the little rubber studs on them. Unfortunately they have a date code of 2007. There is no dry rot and they were stored un inflated on their sides. They hold air and will clean up nice. The rims are aftermarket I believe and marked 15x8 05 09 28 (on three) and 15x8 05 09 27 (on one). The trim rings are also aftermarket. White lettering on the inside tire. Will need to pick up. SOLD
1968 seat with lower release lever. Very nice driver condition with seat rails that operate and move freely. No tears. Someone tack welded extensions under the seat rails to I guess put in another car. Can be cut off easily and still use factory rails. Seat latch works but isn't grabbing, I believe the bottom latch needs to be raised up 1/4" and it would engage and lock. Will need to pick up. $250
1968-1972 fan shroud. Cut up pretty bad. Was original on 1969 350/350.
Pick up only. $10
Fan shroud, plastic. I thought it was for an early C3 but I'm not sure what year. Anyone that recognizes and needs it come get it. $50
NOS 1968-71 drivers side inner fender. Someone cut the front half off. I dont know why but it's cut from the top of the A arm forward. Would be a great patch piece for someone. $50
Chain link steering wheel. Took it off my 1969 corvette. Will trade for 1969 Corvette steering wheel in black. Good condition. No peeling of
chrome. Heavy and solid. Pick up or I can meet for trade.
L1970-1971 front grill set. Original GM. Part numbers 3966793 and 3966794. Will also fit 1972. These came off a front end I bought for my 69. Very good condition. Has amber lenses not clear. These are the lenses that were on it. Has fiber optic hole. $500 each
Pick up only. $10
Parts Sherpa
Ill take the 3956109 shroud. I am passing through first week of oct if thats ok
Mine was trimmed at the bottom mounting tab and this may work for repair material
EarlyC34me (09-23-2017)
Hi,
I really don't need the rims and tires but if you can do $250 for the set, I can pick them up today or tomorrow. I'm right in New Castle about 15 mins away.
Thanks,
Chas
Thanks,
Chas
Just noticed as I was about to edit the ad to mark off sold items that the grills were supposed to $500 each. Somehow it got cropped off when I added the photos.
Wheels are sold and gone. Original fan shroud sold and on hold. Steering wheel in process of trade. Everything else is still available and taking offers. I have been asked about the mount on the 1968 seat rails. I can and probably will grind off the extensions that were added and they will back to just the original seat rails and seat.
