427 SBC: Dart, World, or Blueprint block?
https://www.summitracing.com/parts/w...make/chevrolet
Billet caps, splayed mains, raised cam W/ roller bearings, no clearancing for 4" stroke, no small base circle cam required, priority main oiling, standard deck.
That said if I was going all in I would spend $2000 more and go Brodix aluminum. #100 lighter.
https://www.summitracing.com/parts/b...make/chevrolet
http://brodix.com/blocks-list/small-block
Received 3,043 Likes
St. Jude Donor '05
Nice , didnt know Brodix still made them , wanted a GM alum block but the machinist wouldnt do it for a solid roller st car
What lifter bore dia does that Brodix piece come with? Has some potential there.
.842. Can get them .875 and .903. Whatever you want. That is the nice thing about Brodix, they will do whatever configuration you can think of. Multiple cam heights and bores. These will take a 4.25 stroke crank if that is what you want.
Dr. Detroit
Received 3,892 Likes
Dart Little M.......nodular splay cap is more than enough.
The World block is a great piece too....but Dart gets my money.
Jebby
Jebby
St. Jude Donor '05
a big bore alum.block, some compression, solid roller and an Sb2.2 head
Yep daily driver
Yep daily driver
The Dart SHP is really only made for 3.750 stroke. I spent a lot of man hours clearancing the block for 3.875 to make a 415 ci.
I personally own the Motown. The advantages were over bore clear out to 4.200 or something like that. The raised cam makes it so you don't have to worry about small base circle cams or clearance issues with the rods when using large H beam 6 inch. The other great thing is the large oil port on the upper rear side of the block. It is all setup for exteral oiling like Accusumps. Very necessary for road racing.
The Dart raised cam is also great, but they require specialized timing sets... IE jesel toothed belt cam drive setups.
I have never worked on the Dart little M
Also these blocks come unfinished. So add about $500 to labor at a machine shop. For bore finish, cam borings, freeze plugs, block plugs.....
St. Jude Donor '05
Did a road race motor using a Little M about 8-9 yrs ago would recommend the same thing..its a nice block
Definitely make sure the water jackets are clean, mine was filled with metal shavings would have made a mess had someone just screwed it together lol.
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I have a dart shp short block 427 on the engine stand, bought from jegs as an assy. Everything looks good, Callies rods and crank, I think Mahle pistons. This is replacing a Motown aluminum block that gave me nothing but trouble with rings and pistons. Long story but the short version is the sleeves on the block are too short on the Motown alum block, the piston rocks at the bottom of stroke, even though they sold them as ok for 4" stroke. Now I need to find a project to put the motor in... I can't get myself to mod the c3/lt1.
St. Jude Donor '05
Do it, noone will know except you!
But again, I think this is an anomaly to their aluminum block due to the steel sleeve length.
I used the GMPP Aluminum Block. ( 400 ci) My machinist said it was the first aftermarket Block he didn't have to get the grinder out to make things work.
I used a GMPP Bow Tie Sportsman block (4.125 bore) and would do it again. It was ready to assemble after a hone/final bore sizing, cam bearings, and deck height to suit. The main bearing clearances were spot on with a Callies Dragsonslayer crank. Most people use a 2-piece seal crank, but I used a 1-piece seal block and crank and it is still dry as a bone years later. I can't stand leaks.
Motown, hands down, will accept a 4 in. crank out of the box, no machining required. All five of the crank caps are 4 bolt billet steel and the inner three are splayed.
Unless you botch the assembly or use the wrong parts these blocks will handle north of 7000RPM without braking a sweat.
