Any Ideas ?
Any Ideas ?
Hello........I left both Key pods inside my 2013 427 vert. Battery is completely dead, not allow me to open doors. any trick to getting doors or truck open without keys ? I been having trouble with a drain on the battery, I replaced battery in car and both key pods and thought I had it resolved.......I guess not ! Thanks John
Landru (09-23-2017)
Received 2,093 Likes
The following 3 users liked this post by Vet Interested:
Landru (09-23-2017)
I believe you can remove the left tail light (torx). Maybe remove both lights. Reach in and remove the lining, and grab the emergency release lever on top of the drivers rear tire.
The following 5 users liked this post by RobLo:
buckmeister2 (09-23-2017),
jbc1995fb (09-23-2017),
kevinkar (09-23-2017),
Randy_in_MD (09-22-2017),
Signal_20 (09-22-2017)
Received 1,136 Likes
I have 3 spare keys.
Problem solved........my DW reminded me that last weekend while attending a local car show, I removed a key and left it my truck. ( bad case of sometimer's ) aka Alzheimer's. Thanks for all the ideas, lesson learned ! John.
P S. Car will be going in to find the drain on the battery !
Landru (09-23-2017)
Q: What is a "DW"?
There is at least one (probably several) threads here about how to track down parasitic battery drains.
Battery Drain
Just throwing this out there.
Jim
Landru (09-23-2017)
Thanks Jim........yes the previous owner did have the Mild to Wild installed, thanks for the tip, gives me a good place to start looking. What ever it is, it's taking a heavy draw, fully charged ( new) battery only holds a charge for a few days. John
Been called that a few times too, lol. I did buy a Jr. Trickle charger, didn't think I'd have to use it between weekend drives. I will try to track down the cause of the drain before relaying on the trickle charger... Again thanks for the help everyone, makes us ( me ) first time vette owners appreciate our toys even more ! John
Ideally it's the M2W; which, has a work-around.
Made it SOP hooking-up my Z06 every time it's parked.
Just good policy, if car doesn't start it won't be because of a dead battery.
Since I use an air ionizer plugged-in to cigarette lighter whenever car's parked also I'm sure it'd kill my battery in a day or 2 w/o a trickle charger, anyway.
Received 3,611 Likes
2016 C6 of Year Finalist
Couple things...
As stated, from underneath the car hook positive jumper on the starter and ground the other;
A locksmith/tow truck driver can put an air wedge in the side window to enable a "lasso" to grab the floor door release.
Besides the mild to wild there a number of posts about on-star drawing power.
And, of course, the obvious...you aren't leaving a radar detector/Bluetooth/whatever plugged in...are you?
