Sponsored by: GEM Motorsports
Anyone using Eibach Lowering bolts?? (Z07)
Old 10-04-2017, 10:15 PM
cyi1
cyi1's Avatar
2018 C7 of Year Finalist
Default Anyone using Eibach Lowering bolts?? (Z07)
I've been searching and reading anything and everything on lowering a Z07. I definitely need aftermarket lowering bolts since the stocks don't lower enough and I don't want to drop 3k+ on the LG spindles.
Came across an Instagram Z07 owner and asked him what he's lowered on. Said he's on Eibach and his buddy also. They have 8-10k miles with no issues. It's also not turned to the lowest setting and the stance looks like how I want mine.
Anyone else use these? I hear the stories about the WCC rubber bushing ripping apart within few months to a year and also heard of the pfadt bolts breaking at the joint.
Here's a pic of his stance
View this post on Instagram
I don't see a listing for 2015+ Z06 but all the other aftermarket bolts say the same C6 bolts fit all C6 and c7 models so these should work, correct?
https://m.summitracing.com/parts/eib...oaAry8EALw_wcB
Old 10-04-2017, 10:33 PM
phantasms
Leeds.io
Support Corvetteforum!
phantasms's Avatar
St. Jude Donor '14-'15-'16
I have no answers for you but as someone with a Z07 that has a serious rake I'm very interested in where this thread goes.
Best,
Gene
Old 10-05-2017, 12:39 PM
musclesbmf
musclesbmf's Avatar
Much easier to just cut the bushings/pads on the stock bolts. Every aftermarket lowering bolt uses cheap "urethane" end caps that eventually brake and the metal on metal sound is annoying. The best bolts were the hardbar bolts but those aren't made anymore.
Mark
cyi1 (02-18-2018)
Old 10-05-2017, 01:04 PM
cyi1
cyi1's Avatar
Mark
I'm going to give these a try. Spoke to Eibach and they're same for C6/C7. I've used a lot of Eibach products in the past and they've always been good. Never had an issue and customer service has always been great. I'll let you all know how it turns out.
The following 3 users liked this post by cyi1:
richvegas (10-05-2017), timmyZ06 (11-10-2017), Z06Samuel (10-07-2017)
Old 10-07-2017, 05:27 AM
Z06Samuel
Z06Samuel's Avatar
Old 10-07-2017, 12:39 PM
EMINENT 1
EMINENT 1's Avatar
Those look exactly the same as all the other ones.
I actually got the Zip ones that are advertised to have a convex shape so they don't separate and crack. While that may be true, haven't looked at them since I removed them, they still creak going over speed bumps or anything higher than a 1". Annoying.
Old 10-07-2017, 03:43 PM
MerakiAutoworks
Supporting Vendor
MerakiAutoworks's Avatar
Interested to see how it turns out.
-Josh
Old 10-10-2017, 12:01 PM
cyi1
cyi1's Avatar
Bolts are here. They look like every other lowering bolt
I go in for my 500mi oil change this week, but I think I'll wait until closer to 1500mi break-in period to install these.
Will update you guys once they're in.
Old 10-10-2017, 10:00 PM
JackTripper
Turn 12!
JackTripper's Avatar
Good luck. They look like the same cheesy bolts that failed on me that forced me to buy the LG spindles.
Old 10-12-2017, 12:57 PM
EMINENT 1
EMINENT 1's Avatar
Same here. I agree with others. Might as well just cut bushings so they don't creak.
Old 10-12-2017, 03:19 PM
cyi1
cyi1's Avatar
I heard the cut bushings eventually wear down and creak over bumps also. Is this not true?
Vengeance wants $540 to install lowering bolts + alignment. They want the same price to cut the stock lowering bolt bushings, lower, and align.
Trying to figure out the best route to take.
Old 10-12-2017, 03:38 PM
EMINENT 1
EMINENT 1's Avatar
Sounds about right. I'd cut bushings if you just want it low and don't care about ride. It will suffer.
Personally, if I had to do it over again, i'd save and get the drop spindles. Just saying. As you're probably lowering the life of your shocks too and those things aren't cheap.
If I didn't care about the mag ride, and storing leaf springs away, I would've gone coil overs.
Old 10-12-2017, 04:24 PM
cyi1
cyi1's Avatar
making me second guess lowering, but the 4x4 look needs to go.... I'm waiting until 1500 miles to do anything though so maybe I'll just end up getting the LG spindles by then
Old 10-12-2017, 05:08 PM
Ltrain925
Ltrain925's Avatar
i bought my LG drop spindles for my z07 used and saved a little, lowering my car all the way on stock bolts which didn't do anything for the rear and maybe 3/8ths for the front did make my rid more noticeably stiff, a non-z07 might not have this issues since its a softer ride so anyone that calls BS( and people have) really can't speak unless they have a z07. I do I noticed it firmer and dropping the car on lowering bolts I couldn't imagine how stiff it would be. I would get the spindles from personal experience.
Old 10-12-2017, 06:08 PM
Howdie
Howdie's Avatar
My experience FWIW
I have a Z07 that I lowered on stock bolts. I noticed it took a while to settle, I also think that the car has settled over the first 1500 miles of ownership, so it does not look sky high like it did new. I got maybe 1/2" in the front, and 1/8th to 1/4 in the back (didn't measure). But it does look better, not as low as the picture above though. I didn't notice a firmer ride, in fact this car pleasantly surprises me with the ride quality in Tour. That's just me. If you replace the stock bolts with aftermarket, that, I suspect, impacts ride quality.
Old 10-12-2017, 06:22 PM
cyi1
cyi1's Avatar
Originally Posted by Howdie
My experience FWIW
Is your car making any noises over bumps? I might just cut my stock lowering bolt bushings if that's better than switching to an aftermarket bolt with urethane bushing.
Are there any cases of cut stock bolts that caused suspension noise?
Old 10-12-2017, 06:26 PM
Howdie
Howdie's Avatar
No, no weird noises for me.
To Anyone using Eibach Lowering bolts?? (Z07)
Old 10-12-2017, 06:32 PM
cyi1
cyi1's Avatar
Great. I'm back to square one where I have no idea what to do lol
Old 10-14-2017, 01:46 AM
gymdoc
gymdoc's Avatar
I lowered my z07 on stock.. after a few weeks it started to creak in the rear.. then it got worse to the point that I thought I had a loose tie rod or something but I didn't have the time to dig into it and kept using the car and surprisingly it started to go away.. and finally its totally gone. The whole thing lasted about a month and its all good now.
Old 10-14-2017, 10:12 AM
cdh027
cdh027's Avatar
There is a chance that the noise was your lower control arms grinding a groove in your spring. Once it dug enough material out, it no longer made noise.
Quick Reply: Anyone using Eibach Lowering bolts?? (Z07)
