Vararam needs a few C7 Z06's in the Houston area for testing!
Supporting Vendor
We need help with our new C7 Z06 air intake.
If you are in the Houston area and would like to help PM
us here or via email at vararamindustries@gmail.com
Thanks for the help
VR Tech
Thanks for the help
VR Tech
Former Vendor
Thanks for the help
VR Tech
Thanks for the help
VR Tech
Supporting Vendor
Supporting Vendor
We are still looking for more cars to run tests on. If your in the Houston area , give us a call or drop us an email.
713-477-8100
email vararamindustries@gmail.com
VR tech
713-477-8100
VR tech
Supporting Vendor
Supporting Vendor
Supporting Vendor
I will contact you direct.
VR tech
Just curious, by you doing this. What benefit will the owner of the ZO6 get from VaraRam? I have a 2017 C7 ZO6 Auto with 180 miles on her. I live south of Houston in Lake Jackson! Thanks!!
I sent you a E-mail
I sent you a E-mail
Supporting Vendor
combined with increased reliability and performance consistency.
When I data Log stock LT4 cars in normal TX weather (+2,500-3,000+ DA) and see up to -6.9deg of knock retard and boost is down by 2lbs or more, massive gain is a true understatement.
VR tech
Former Vendor
Great folks over at Vararam! I personally had one on my Corvette and loved it and even got one for my Uncles Dodge ram and he swears by it!
Supporting Vendor
Andrew6@TheDoubleAA (01-04-2018)
You will see massive Power and Torque increases,
VR tech
VR tech
Thanks for your comments on the issue.
Ernie
Supporting Vendor
I have not logged my stock LT4, but know it generates a fair amount of knock retard as I can hear a slight bit of audible "pinging" from time to time. (Thanks, CARB, for our 91 octane fuel.) Do I understand your comments correctly -- that your intake design will reduce the amount of knock retard and therefore the possibility of "pinging" on 91 octane fuel?
Ernie
Ernie
Your not knocking from91 fuel. GM engineers for that in the stock ECM's commanded timing and AFR numbers. Your knocking from excessive restriction and some heat soak.
The numbers that I posted for stock were using 93oct Shell gas that we test for contaminants.
VR tech
Thanks for the help
VR Tech
Thanks for the help
VR Tech
Thanks.
