Good "low grunt" cam?
Base 2004 manual C5. I love the way it drives but I wouldn't mind having a little more "grunt".
I was originally looking at doing a 224/224 112LSA (had the old TR224 in my Z28 and loved it), but now I'm wondering if even that's more cam than I really want. I almost never turn past 4K (not into getting out and racing anymore) and I don't want to kill gas mileage (DD and I'm enjoying 30+ MPG). Just looking for a little more idle lope and low/mid range zip.
So I'd appreciate some suggestions on more torque related cams (obviously bigger than an 02 Z06 cam). I'll be installing Kooks (or LG) LTs and upgrading valve springs, but plan to leave the stock 241 heads.
VFR RC46 (11-28-2018)
To clarify, you're saying get the 224/224 112 and advance it 4 to 6 degrees (bring the peak down)? If I remember correctly, (in the case of the TR224) the cam is likely to already have 4 degrees of advance ground into it. So you are suggesting 8 to 10 degrees of advance? Any issues with P-to-V clearance with that much advance?
There are better cams out there. Go to LS1tech.com. I'm not going to say that most people here don't know what they are talking about with cam choices, or that there is very limited talk on cam swaps here on the corvette forums, BUT I will say over on LS1tech.com there is a lot more talk, banter and experience with cam swaps...
Sounds like you want to go mild.. I'd suggest the Streetsweeper TQ in that case, but not sure why your keeping it under 4,000rpm for all your driving. Fun doesn't even start until 4k rpm IMO..... There are lots of cams these days that make power everywhere over stock... so if you want the power down low and you want to wind out to 7000rpm you could look at the Streetsweeper HT.
The following 2 users liked this post by Roddy13:
CorvetteBrent (12-02-2018),
Edit: I just looked up that Streetsweeper cam. That's not really any smaller than a standard 224 cam (same lift, lower LSA).
There are a ton of options out there, enough to make your head spin. I agree, there's lot of reading available on the LS1tech forum to give you a better understanding of cam specs, etc.
Previously I had a TR220 cam, 241 heads, LT's, etc. (all from the PO). Made 370/370 at the wheel. Power was smooth. Sadly I had a #7 piston failure and so I'm building a new motor.
A big consideration for me was cam ramp rates. very aggressive lobe ramp rates can be tough on valvetrain components. Cam Motion is considered a good choice for lobe design. I just bought their Titan 4 cam to go with some cnc ported 243 heads. For your needs you might look into the Titan 2. (221/226 112+2, .595/.586). I'd suggest giving them a call to discuss the details. Another nice feature of their cams is that they offer upgrade cam core materials. I opted for the 8620 material.
The following 3 users liked this post by bigmackloud:
Supporting Vendor
It's not that I never go abover 4K, it's just that in my daily driving I don't get over that (too much traffic in the city). As a result, I'm looking to build more low/mid range usable torque rather than have a dyno/track queen that has lots of high RPM HP that I almost never use.
http://www.cammotion.com/camshafts/t...218-222-112-3/
The following 5 users liked this post by cammotion perf:
bigsapper (07-20-2019),
ChrisLSx (10-13-2017),
Roddy13 (10-13-2017),
Sam Handwich (10-14-2017)
I just placed my order for the Cam Motion Titan 3. It is supposed to arrive Monday Oct 16. I was also looking for as much Low end performance as possible. I participate in Road Course HPDE. I am very excited to get it installed, tuned and Dynoed. I have a BPP Vortex Rammer, Fast 92 intake, ported LS2 Throttle body, Livernois Stage 2 ported heads and AR Headers to compliment the cam. Being in Michigan I won't get to track it till next season.
The following 2 users liked this post by Bossdog:
ChrisLSx (10-14-2017),
I installed a Comp 216/220 low lift (.530 or so I think) in a 2004 convertible, with LG headers & hi flow cats, Blackwing, and a tune.
We got 382 rwhp and 372 rwtq with no other mods. Low-end torque is awesome, and the idle is really, really clean with a nice audible thump. Up to 30 MPG on the highway.
Neat thing about the lower lift is there is absolutely no worry about valvetrain stress, and no loss of midrange torque at all. One of the best kick-around combos I've seen.
DG
DG
The following 2 users liked this post by The Wrench:
DG
DG
Received 1,679 Likes
The following 2 users liked this post by FX VETTE:
Roddy13 (10-24-2017)
Supporting Vendor
__________________
The Switch Is On To Cam Motion!
40 years of Championship Winning Experience • Superior 8620 Steel Camshaft Cores • Quiet, Smooth & Powerful Lobe Design • Virtually Unlimited Lift and Duration Combinations • Finish Polished For Quiet Operation • Cam Doctor Printout With All Cams
The Industry's Best Customer Service
www.CamMotion.com • ☎ 866-461-9536 • Like Us On Facebook!
I got a call from the shop putting in my cam + tune today. Amazing good fortune, they found a broken outer valve spring that had not caused failure. The springs were Patriot Extreme springs and were installed in 2012. Don't know how many Track hours were on them. My guess is 70 to 80 hours. The technician indicated that the springs were clearly in need of replacement.
The engine tech also recommended changing out the Generation 1 Yella Terra Rocker arms that are currently installed as he was aware of many issues with them failing, that there was an inherent weak point in the design that caused failure. So I'm putting the stock roller rocker arm back in.
If you are going back to stock rocker, you could do a Straub bushing trunion upgrade, I would stay away from needle bearing trunion upgrades
Bossdog (10-31-2017)
By today's standards, Yella Terra rocker arms are junk. They are really heavy and don't provide any benefit over stock rockers with upgraded trunions.
