Detail Job
The following 2 users liked this post by Ramler:
Art17 (10-16-2017),
Perf n Restore (10-22-2017)
Received 1,679 Likes
looks good
Nice job looks great.
Received 7,753 Likes
CORVETTE TODAY Host
St. Jude Donor'15
More pics....
JimNeedsC7 (10-14-2017)
I'm interested in hearing your thoughts on the C-Magic Radiant, it's something I might like to try in the future myself. It sounds like one of the more user friendly ceramic coatings to apply.
Nice and Shiny
That front plate looks like it would do some damage mounted like that.. Might catch something?
If i were you and you was me??It would be in the trunk until i got pulled over say....50 times before mounted...Ohh,Right your not me
Thanks for your service
To the OP, your car looks excellent!
My understanding of product use from C-Magic is to prep surface the way you want it and wax then detail spray then Radiant on top. Then you can add as many coats of Radiant you want following the curing time...is that right?
Thanks,
Thanks,
That is correct. The more Radiant, the more protection and shine.
c54u (10-15-2017)
That is a Sto N Sho from Big Mike's. Had one on my last GS also. They probably take less than an inch of ground clearance and can be removed in no time. Never had a problem with them. You're right, I should have taken it off before the pics.
Wouldn't the detail spray be the last step after putting on Radiant? Also, why bother with the wax step, wouldn't just Radiant alone provide the shine?
The detailer spray wax can be used on top of the Radiant if you want, but I would assume you would want the Radiant on top for the qualities I mentioned above.
http://www.cmagicwax.com/APPLICATION%20INSTRUCTIONS.pdf
http://www.cmagicwax.com/PRODUCT%20DESCRIPTIONS.pdf
Patman (10-15-2017)
Come do mine, you're not too far
Received 5,216 Likes
Looks good... now, if you'd just come and do mine... hehehe!
