Transmission tunnel insulation installation question
I have new clips installed on my 65 and I need to attach the insulation. Do the clips push through the cardboard-like material? Do you need to cut slots for the clips to fit through? I'm not sure what's the best way to approach this so I'm looking for advice from those that have already done this.
Thanks
Thanks
Thanks
Thanks
I installed my new tranny tunnel insulation material this afternoon in my 66. I made sure each clip was straight. I squeezed the insulation in a little and then pushed it up making sure the shifter opening was lined up. I then just pushed the insulation against the clips and it penetrated the insulation very easy. I then just taped the clips over against the insulation. Very easy task. Hope this helps.
Don
eyedocs,
Don
Don
eyedocs96 (10-17-2017)
I forgot to put mine on when the body was off. There's still a small section left in the rear of the tunnel, but I'd really like to put a new one on. How hard is it to do with the body on or is it even possible? Secondly, if I don't put a new one on, am I making a mistake?
Thanks,
Dex.
Thanks,
Dex.
Thanks,
Dex.
Thanks,
Dex.
eyedocs96 (10-20-2017)
Thanks,
Dex.
