Question about tonneau cover not closing properly
Well,I did a search and can't seem to figure out what is going on, so I'm reaching out to my smarter friends.
Out of the blue in my 2008 the tonneau cover will latch to the receiver bar but will not pull down the last couple of inches. Everything else about the top works ok. I've checked all the things mentioned in other posts but it looks like I don't really understand the mechanics of how this top works. I'm assuming there's an actuator or motor that pulls the receiver down to lock the top?
I read about the microswitch but not sure what it's function is in the process. I can do a few mechanical things but no gear head so any direction you guys can give me would be appreciated.
Pro Mechanic
Received 3,952 Likes
here you go.................... link below................. probably the actuator............. known to have issues with the gear.............
https://www.corvetteforum.com/forums...-pictures.html
I hope you get this sorted out. One reason I went with the manual top.
Hope this solves my problem. I'll be sure to post what happens
That left the motor and switch, but I decided to just replace the whole thing since the housing was plastic. I'm keeping the old part in case this happens again and then I'll try just replacing the gear which was only about $8 on Amazon. I didn't want to throw parts at this issue since the car is already 10 years old.
Anyway, Rock Auto was very quick shipping and the part with shipping was just shy of $200.
thanks again.
Pro Mechanic
drich, THANK YOU for posting the follow-up as it may help someone else further down the road..................
glad you got it sorted out...................
