WTB: Upper pan needed asap
Well drilling and tapping the pan is a pita while the pan is in the car. I ended up chipping some of the threads some how and the hole will not seal. So I'm looking for an upper oil pan. My failure picture is included 😡
I have a 1 piece pan off a 00 C5. $200
but id strongly recommend you buy a C6 oil pan instead. Its a direct bolt in as long as you get the C6 pick up tube. If you get one for an 08-13, it runs a better oil filter set up that's capable of a little more oil volume through it.
