Rear ride height issue
Question for my peeps.
New glass spring and I'm wondering if I need to remove that spacer above the spring. Or put in a smaller one. Notice my bolt threads don't go past the diff.they are even with the top. Also it looks like I may need longer bolts to get the ride height down. But I'm wondering if that spacer is the problem.
TRW style spring?
Removing the spacer will help a bit. Looks like you've already got longer spring bolts, what you really need is a flatter spring.
normal to have some threads showing below the cast housing .
Just thinking if you cut spring will it raise it more because it has changed spring tension.
