C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
starter motor stayed engaged
Old 10-18-2017, 09:33 PM
Lawdogg
Lawdogg's Avatar
Default starter motor stayed engaged
Started the car and the starter stayed engaged. Hit the off button and engine shut off, but the starter motor continued to run. Kept holding the off button and it took about 5 more seconds before starter stopped. Any ideas? Starter button bad? PCM? I've started it a dozen times since and it acted normal. Thanks!
Old 10-18-2017, 10:05 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Starter relay stuck maybe? In the fuse block under the hood.
This one here: https://www.corvetteforum.com/forums...post1592161765
Could be the onset of a failing starter solenoid as well.
Lawdogg (10-19-2017)
Old 10-19-2017, 04:46 PM
Lawdogg
Lawdogg's Avatar
If it happens again, I'll try a new relay. Thanks!
Old 10-20-2017, 06:27 AM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes on 578 Posts
Check voltages before throwing parts at it! It's a simple check. It could be a sticking starter solenoid, among other things...
Lawdogg (10-20-2017)
Old 10-19-2020, 06:43 PM
C6ToGo
C6ToGo's Avatar
Received 1,116 Likes on 693 Posts
Amazon open-box $9.51
To starter motor stayed engaged
Quick Reply: starter motor stayed engaged
