L-88 hoods
L-88 hoods
I want to put an L-88 hood on my 69 but I'm not sure which one to get. I know that press molded hoods are better than hand laid hoods but they cost a lot more than I want to pay for one. With that being said, I'm looking at a hood on ebay from a seller named "its-fiberglass". The price is decent and they use fed ex shipping that will ship direct to my home address, I don't have to pick it up from some unknown freight company that will most likely be on the other side of town. They have a 100% positive feedback rating but I was only able to find one feedback for a hood, the buyer seemed satisfied with it. It looks like a nice hood but has anybody here bought one from them? If so how was the quality and the fit? Here is the link to it:
https://www.ebay.com/itm/C3-68-72-L-...19.m1438.l2649
That looks like the tall version of the L-88 style of hood. The tall version is about 2" taller than the standard version so make sure that's the stye you want before spending a lot of money then getting something you don't want. I have the standard version and it will barely clear my Air Gap intake on my 454" and using a 14" X 3" drop base air cleaner that was cut down a further 3/4" in height.
I found one on Craigslist locally with the airbox already installed. But best of all I could look at it in person to decide then and there if it was the one I wanted for my car. And like 71 pointed out, it looks like the tall version. Which means while driving it, it will obstruct your view a bit. Does your engine make it so you need the taller hood? Its a pricey part to say the least, and I imagine shipping is not cheap either.
Not trying to be negative about it, but make sure its what you want.
Ok if this is the "tall" hood does anybody have a link to a standard L-88 hood for sale somewhere so I can see the height difference and decide which one I want?
By the way, don't go by the first pic in the eBay auction because it makes the hood look taller than it really is. Look at the second and fourth pics in the auction instead, it's a much better image that shows the true height of the hood.
http://www.acivette.com/aci0013m.htm
AmericanCustomInd (10-19-2017)
Ok I've been talking with the seller on e-bay, he says it's 2-1/4 inches taller than a stock flat hood, that it's the same height as a stock L-88 hood. Is that figure correct, is a stock L-88 hood 2-1/4 inches taller than a stock flat hood?
L-88 Style Hood
I have run this style hood in the past and they look good. One negative is that on a long road trip the open area at the back of the hood will allow engine fumes to enter into the ventilation inlet btx the hood and wiper area. just be aware of this, may not happen for you but it sure did on my car.
Also looking at the underside of the hood it looks asthough the blister has been added to a standard BB hood
Rey
I have the standard L-88 hood on my '69 (Ecklers). See the picture in my signature. I just bought the extra tall one (about 1½" taller than the standard one).....it's taller but looks about the same; you have to see them next to each other to really tell. Both give you about the same windshield view.
Can you get me some measurements?
C3 Stroker,
I'm having quite a time getting accurate measurements of the Ecklers "High" L88 hood. It looks like you have one. Eckler's says they give 4" tall at the cowl which is fine but how far forward does that clearance extend before the drop off for the front? They don't know.
I have a ZZ502 with the GM intake and a 4150 Holley and 3" air cleaner.
With a straight edge running left to right across the top of my Air cleaner I measure just at 5 1/2" to the top of the drip rails in the fenders. The Ecklers high L88 measures 4 5/8" at that point. 1/8" does not allow for a wing nut to hold the cir cleaner on.
Since you're running the high L88 hood, can you measure what you have across your air cleaner to the drip rails?
I just don't see why my engine is so tall over anyone with the same setup.
Thanks, Brian
Thanks, Brian
C3 Stroker,
With a straight edge running left to right across the top of my Air cleaner I measure just at 5 1/2" to the top of the drip rails in the fenders. The Ecklers high L88 measures 5 5/8" at that point. 1/8" does not allow for a wing nut to hold the cir cleaner on.
Thanks, Brian
Thanks, Brian
ajrothm (05-10-2018)
I used that same hood for my 68 BB, its one of the nicer
hoods out there, I think he is out of Indiana
I spoke at length with this ebay seller John Plodzik from Ohio. Says he has been doing this for a long time. Seemed very knowledgeable and ready to help. He’s willing to ship greyhound which for me is a plus as it’s simple enough to go to the greyhound station to pick up a hood.
Another plus is once you pay him he makes the hood within a week. A lot less time to get one vs ecklers.
I chose the Baldwin Motion III GT hood. I love it. https://www.ecklers.com/corvette/196...-376049-1.html
