Engine Mods Outrageous Builds, High-Horsepower Modifications, strokers, and big cams for the Corvette
New "Vintage" Trick Flow heads
Old 10-19-2017, 03:22 PM
TrickFlowTech
Supporting Vendor
TrickFlowTech's Avatar
Default New "Vintage" Trick Flow heads
The time has come, and our new DHC 175 cylinder heads for small block Chevy are available for purchase! They are being assembled as we speak, and will be shipping by the end of the week!
Trick Flow's new DHC 175 cylinder heads give small block Chevy enthusiasts a new performance option. No longer will anyone have to choose between vintage looks or modern cylinder head power, with DHC 175 heads you get both!
DHC 175 heads are made from premium grade A356-T61 aluminum and have the exterior styling and straight spark plug holes that deliver the nostalgic appearance customers want. On the inside, 60cc CNC-profiled combustion chambers with blended bowl machining under the valves and small cross-section intake runners promote low-RPM torque increases and boost high-RPM horsepower! The runners are finished with Trick Flow's superior Fast As Cast process that precisely duplicates the runner profile and performance levels of fully CNC-ported heads without the added machining cost. In keeping with the vintage design, the heads are available with or without accessory bolt hole cast into them.
Not only that, 40 lbs. comes off the nose of the car! $740.97 ea. with .600 lift Hydraulic roller springs...with or without accessory bolt holes drilled. On a 350, 60cc chambers net 10.6:1 with your average 5cc flat top piston, .040 gasket, and .010 in the hole at tdc. This is fine for pump gas. A 327 will be 10:1.
Old 10-20-2017, 10:34 AM
bosco022
bosco022's Avatar
Would these compare favorably with the GMPP fast burn 23 degree heads ?
Old 10-20-2017, 11:49 AM
TrickFlowTech
Supporting Vendor
We beat it handily. Mid-lift flow is better. Exhaust flow is way better. The bigger deal is we achieve it with a 175cc runner instead of 210cc. It's a very high-velocity port. We also have standard port locations instead of raised with the fast burns. Independent flow tests of the GM Fast burns hover around:
.200 133 Int. / 98 Exh
.300 183 / 129
.400 225 / 150
.500 254 / 171
.600 244 / 179
Our casting and machining is superior and consistent compared to o.e. contract work.
Old 10-20-2017, 04:31 PM
bosco022
bosco022's Avatar
Thanks, sounds like an excellent value. Better performance at a lower price.
Old 10-20-2017, 05:02 PM
TrickFlowTech
Supporting Vendor
Yes sir, we think so as well. Price is $740 ea. with guideplates and studs with the hydraulic roller spring package. Here's a page out of our catalog with all the specs.
Chrisbequick (04-04-2021)
Old 10-21-2017, 07:27 AM
bosco022
bosco022's Avatar
Looking at building a pump gas 383 for a mid 70's 4 speed Vette. Should have the accessory bolt holes for that application...correct?
Old 10-23-2017, 03:19 PM
TrickFlowTech
Supporting Vendor
Yes sir, those would have had the newer accessory brackets.
Old 10-24-2017, 05:11 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
whod have guessed TF is making flathead parts too. Come a long ways..
Old 10-25-2017, 01:16 PM
TrickFlowTech
Supporting Vendor
Folks, we want to share some of our initial dyno testing on these heads. This was on a Chevrolet Performance 350/290 horsepower shortblock, the DHC 175 heads, and our street burner dual-plane.
The original crate engine has some pretty sorrowful 8.1:1 compression with 76cc heads. Putting the 60cc chambers on bumped that up to 9.6:1. Two cams were used.
The Summit SUM-1105 hydraulic flat tappet is a 224/234 duration, 114 Lobe Separation, and .466/.487 lift cam. This is comparable to the L79 cam at 221 degrees of duration, 114 L/S and .447 lift. Also comparable to the L46 cam at 222 degrees, 114 L/S and .450/.460 lift. It produced 398 horsepower and 388 ft./lbs. of torque.
Next up was the TFS-31402001. This is a hydraulic roller with 230/234 Duration, 110 Lobe Separation. .528/.539 lift. With this cam, the engine produced 430 horsepower and 400 ft./lbs.
Both cams, compression, and short block are pretty mild, durable and very comparable to what most people have. There are some dyno tests for the 350/290 factory crate engine with a similar cam produces. For now, here's a quick testing video.
Facebook Post
bosco022 (10-25-2017)
Old 01-10-2018, 10:22 AM
DMITTZ
DMITTZ's Avatar
This looks like a really great product. Wish I hadn't already just built my 355ci. I will keep it in mind for next time I decide to rip into my engine for more power.
Old 01-22-2018, 08:04 AM
Drothgeb
Drothgeb's Avatar
https://www.facebook.com/TrickFlowSp...5258894536715/
I’ll be using a 225/225 .532/.532” (w/1.52 rockers) cam. Would there be any benefit to going with 1.6 rockers and raising lift to .560”?
Old 01-22-2018, 04:43 PM
TrickFlowTech
Supporting Vendor
Absolutely. Always picks up power and torque.
Old 01-23-2018, 07:26 AM
Drothgeb
Drothgeb's Avatar
Thanks for the input. I now have a question on the valve springs.
I’m looking at the specs on the 1.46” valve springs and am a little confused. The TFS-16315-16 springs have one set of specs listed with the DHC-175 heads, but different specs when installed on different heads or bought individually. Can you tell me what the actual spring rate for these springs is, and what the actual installed height and tensions are as installed on the DHC-175? The math for tensions listed on the literature for these heads just doesn’t work out.
I’m guessing the installed height is 1.85” instead of the 1.95” listed. That works out with the 420lb rate listed. But not with the 438lb rate listed when buying the springs separately.
The specs are critical to me for deciding on whether to use the Comp Magnum or Pro Magnum rockers.
Old 02-24-2018, 04:41 PM
Bikespace
Bikespace's Avatar
Received 3,140 Likes on 2,330 Posts
Do the heads have a raised valve cover lip? I'd like to know if I can run stock LT-1/L-82 with 1.6:1 roller-rockers without needing an adaptor. Thanks!
Old 05-03-2018, 06:52 PM
Jeffrey S. Foster
1st Gear
Jeffrey S. Foster's Avatar
Any luck with those new heads I very interested in seeing how they perform? How are people installing the heads ? Stock or a little port work for the larger sbc’s in the 383-406 range. I am thinking of buying them bare then have a little port work and a 2.05 valve for my HR 406. Thanks jeff
Old 09-05-2020, 07:51 PM
stocki26
stocki26's Avatar
What parts/heads would you recommend for a original 1969 L46 350cui-350hp orig. 11:1 ?
I would love to keep valve covers and cast iron exhaust...
Old 03-24-2021, 09:14 PM
bosco022
bosco022's Avatar
I am going to use the TF DHC 175 heads on my original 64 327 block. Aiming for about 400 HP on a 10.5 compression motor with maybe the Comp 280 H cam, Edelbrock intake with Holley 750. Quality headers will replace the 65 sidepipes. These heads make some good number out of the box.
To New "Vintage" Trick Flow heads
Old 04-16-2021, 08:10 AM
Pawlikowska Mathieu
Pawlikowska Mathieu's Avatar
Hi everybody,
I would like to buy these cylinder heads for my L82 engine but I have a choice to make : 0.540 max valve lift or 0.600 max valve lift for the best performance ?
What's your advice ?
Old 04-16-2021, 06:46 PM
Cozmacozmy
8th Gear
Cozmacozmy's Avatar
Originally Posted by Pawlikowska Mathieu
Hi everybody,
It depends on what cam you have.
Old 04-17-2021, 08:36 AM
Pawlikowska Mathieu
I have this one : Camshaft, Hydraulic Flat Tappet, Duration @ .050 in. 222/222, Lift .450/.460
https://www.summitracing.com/parts/nal-3896962
Quick Reply: New "Vintage" Trick Flow heads
