Vacuum lines 1977
10-19-2017, 09:03 PM
Cruising
Vacuum lines 1977
It's time to install vacuum tube lines. It looks like there are two different sizes. Is it 3/8 and 1/8 or 3/16 inside diameter?
10-19-2017, 11:59 PM
Quote:
Originally Posted by
CascadeDiver
I found that Corvette 101 .com will explain your vacume lines that is if your talking about your headlights!
Good luck with your build!
10-20-2017, 12:59 AM
Does this help?
10-20-2017, 06:56 AM
Cruise-In II Veteran
CascadeDiver
...It's time to install vacuum tube lines...
Which vacuum lines? Headlight or engine?
10-20-2017, 01:38 PM
Cruising
Peterbuilt
Does this help?
Great information. Thank you!
10-20-2017, 01:39 PM
Cruising
SPCL FX
Wonderful, thank you
