(@Y@) FRIDAY FUNNIES Oct 20th (@Y@)
Received 2,827 Likes
Crowd Plow For Now
getting colder all.... start to cover up the toys now....
Feel free to add to "your" thread here
..... and now for some GIF's
Crowd Plow For Now
Lying around, pondering the problems of the world, I realized that, at my age,
I don't really give a rat's *** anymore.
If walking is good for your health,
the postman would be immortal.
A whale swims all day, only eats fish, and drinks water,
but is still fat.
A rabbit runs, and hops, and only lives15 years, while a tortoise doesn't run, and does mostly nothing, yet it lives for 150 years.
And they tell us to exercise? I don't think so.
Now that I'm older, here's what I've discovered:
1. I started out with nothing, and I still have most of it.
2. My wild oats are mostly enjoyed with prunes and all-bran.
3. Funny, I don't remember being absent-minded.
4. Funny, I don't remember being absent-minded.
5. If all is not lost, then where the heck is it?
6. It was a whole lot easier to get older, than it was to get wiser.
7. Some days, you're the top dog, some days you're the hydrant.
8. I wish the buck really did stop here; I sure could use a few of them.
9. Kids in the back seat cause accidents.
10. Accidents in the back seat cause kids.
11. It is hard to make a comeback when you haven't been anywhere.
12. The world only beats a path to your door when you're in the bathroom.
13. If God wanted me to touch my toes, he'd have put them on my knees.
14. When I'm finally holding all the right cards, everyone wants to play chess or dominoes.
15. It is not hard to meet expenses . . . They're everywhere.
16. The only difference between a rut and a grave is the depth..
17. These days, I spend a lot of time thinking about the hereafter . . .
I go somewhere to get something, and then wonder what I'm "here after".
18. Funny, I don't remember being absent-minded.
19. It is a lot better to be seen than viewed.
20. Have I sent this message to you before...or did I get it from you?
Always do right. This will gratify some people and astonish the rest – Mark Twain
Tools and Their Proper Application
TOOLS AND HOW TO USE THEM
SKIL SAW:
A portable cutting tool used to make boards too short.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light.
Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say,
'Oh ****'.
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
Channel Locks:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VICE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available,
They can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for igniting various flammable objects in your shop and creating a fire.
Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
Very effective for digit removal.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut large pieces into smaller pieces that more easily fit into the trash after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of all the crap you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt.
But can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
PVC PIPE CUTTER:
A tool used to make plastic pipe too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door.
Works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts.
Especially useful for slicing work clothes, but only while in use.
SON OF A BITCH TOOL:
Any handy tool that you grab and throw across the garage while yelling "Son of a bitch" at the top of your lungs.
It is also, most often, the next tool that you will need.
A man went to pick up his date but he was having some trouble with his flatulence system, in other words he couldn't stop farting so when he had to wait for the young woman to get ready for the date he sat on the lounge and let out just a little fart when the dog hopped onto the couch with him. He figured that the parents would think it was the dog. Every time he farted the young girl's parents told the dog to get off the couch and so the man kept going, finally he let rip and the parents finally told the dog to get off the couch before the man **** on him!
A man goes to a shrink and says, "Doctor, my wife is unfaithful to me. Every evening, she goes to Larry's bar and picks up men. In fact, She sleeps with anybody who asks her! I'm going crazy. What do you think I should do?" "Relax," says the Doctor, "take a deep breath and calm down. Now, tell me, exactly where is Larry's bar?"
The couple had been married for twenty years. It was a happy, wonderful marriage, except that the wife was very unfaithful. The husband finally got so tired of her unfaithfulness that he made her promise to never again be untrue to him. One day he came home and found her in bed with a midget. He cried out, "My wife, my love, after you made all those promises, I find you in bed with another man, and a midget at that!" She replied, "My dearest husband, the love of my life, do you not believe me, do you not see, do you not understand? I am tapering off."
Two men are sitting in the doctor's office. The one looks at the other one and says, "What are you here for?" The man replied "I have a red ring around my pecker, What are you here for?" The other man said, "I have a green ring around my pecker." The doctor called the man with the red ring first in his office and examined him. As he was walking out he told the other guy it was no problem. The doctor called the man in with the green ring around his pecker and examined him. The doctor says, "Your pecker is gonna fall off and you are gonna die". The mans says, "What?? You told the man with the red ring he was ok, but I'm gonna die??" The doctor said, "Yes but there's a lot of difference lipstick and gangrene!"
Three Italian nuns die and go to heaven. At the Pearly Gates, they are met by St. Peter. He says "Sisters, you all led such wonderful lives that I'm granting you six months to go back to earth and be anyone you want to be."
The first nun says, "I want to be Sophia Loren;" and *poof* she's gone.
The second says, "I want to be Madonna;" and *poof* she's gone.
The third says, "I want to be Sara Pipalini."
St. Peter looks perplexed. "Who?" he says.
"Sara Pipalini;" replies the nun.
St. Peter shakes his head and says; "I'm sorry, but that name just doesn't ring a bell."
The nun then takes a newspaper out of her habit and hands it to St. Peter. He reads the paper and starts laughing. He hands it back to her and says "No sister, the paper says it was the 'Sahara Pipeline' that was laid by 1,400 men in 6 months."
There were these three farmers that wanted to win the state fair contest for having the largest hog. They decide that they should stick a cork in the pigs *** and feed him for a month before the fair. The only problem was that none of them wanted to be the one to stick the cork in. So they bought a monkey and trained him to stick corks in bottles. After a week or two of this, they stick the monkey in the pen with the pig and a cork, and after a minute, the monkey did what he was supposed to do. The farmers fed the pig for a month and sure enough, they won first prize. Once they got home, they realized they still had to take the cork out. So they trained this same monkey to take corks out of bottles. They stuck the monkey in the pen with the pig, and the farmers woke up three days later in the hospital with a reporter sitting next to them. The reporter asked the first farmer, "What is the last thing you remember?" "**** flying everywhere," the farmer replied. The reporter asked the second farmer the same question and got the same response. When she got to the third farmer and asked him what he could remember, he started crying. The reporter asked, "What's the matter?" The farmer replied, "The last thing I remember is the look on the poor monkey's face as he tried to stick the cork back in."
A fellow went off on his honeymoon, and after returning meets up with a friend for a beer and conversation. The friend, being single and a pervert to boot, begins to inquire as to the festivities of the honeymoon. "So, Bob, big married man, did ya get any while you were out there?" the friend asks. Bob just shakes his head. "Ah, you know me. I like to fish. So I just fished." His friend gasps. "You mean you didn't have no sex? C'mon, Bob, tell me at least got a *******!" Bob again shakes his head. "Naw, she had pyorrhea, so I just fished. You know I like to fish." His friend replies, "Bob, she's your god damn wife! She's gotta give it up when you say! You should just made her do it!" Bob replies, "Nah, she had gonorrhea, and you know me. I like to fish, so I just fished." His friend, now quite upset, says, "What?! Why didn't ya just pork it up her ***?" "Well," says Bob, "she had diarrhea...and you know me, I like to fish. So I just fished." His friend, totally exasperated by this point, shouts at him, "Jesus! Why'd you marry this sick bitch anyway?!" Bob replies, "Well, she got worms, and you know how I like to fish..."
One Night After Watching Who Wants To Be A Millionaire... A man and his wife went to bed and the man was getting very frisky. He asked his wife if she was in the mood. His wife answered, "Not tonight dear, I have a headache." The man replied, "Is that your final answer?" She said "Yes." "OK, then I'd like to phone a friend." he replied.
There was this geriatric woman who thought she needed some toughening to cope with today's world, and decided to join a gang. She rocked up to the Hell's Angels bikers club and tapped on the door. "Excuse me, sirs, I'd like to join your club if you please" she croaked in her feeble voice. A grunt came from inside, "Ha! You got no chance, woman. We only take the toughest into our club. You can only join if you drink!". "Oh boy, do I drink! I slam a few down every night after playing pool with the boys" she croaked back. "Oh, umm, well... you can only join if you smoke" he lied, trying to brush her off. "Does marijuana count? Coz I don't mind a few joints after playing pool with the boys". "Umm, I suppose it does count..." the biker said, and, thinking quick on his feet said "Look, we're a gang only for the roughest, toughest men in town. Now, have you ever been picked up by the fuzz?"
"No," she replied, "but I've been swung around by the **** a few times".
A friend asked me the other day why I never got married. I replied "Well, I guess I just never met the right woman... I guess I've been looking for the perfect girl."
"Oh, come on now," said my friend. "Surely you have met at least one girl that you wanted to marry."
"Yes, there was one girl... once. I guess she was the one perfect girl -- the only perfect girl I really ever met. She was just the right everything... I really mean that she was the perfect girl for me."
"Well, why didn't you marry her?" asked my friend. I shrugged my shoulders and replied, "She was looking for the perfect man."
A husband and wife are traveling by car from Atlanta to New York. After almost twenty-four hours on the road, they decide to stop at a nice hotel and take a room. They only plan to sleep for four hours and then get back on the road. When they check out four hours later, the desk clerk hands them a bill for $350. The man explodes and demands to know why the charge is so high. He tells the clerk although it's a nice hotel, the rooms certainly aren't worth $350. When the clerk explains that $350 is the standard rate, the man insists
on speaking to the manager.
The manager enters the conversation and explains that the hotel has an Olympic-sized pool and a huge conference center which were available for the husband and wife to use.
He also explains that they could have taken in one of the shows which the hotel is famous for. "The best entertainers from New York, Hollywood and Las Vegas perform here,"
explains the manager.
No matter what facility the manager mentions, the man replies, "But we didn't use it!"
The manager is unmoved. Eventually the man gives up and agrees to pay. He writes a check and hands it to the manager. "But sir," the managers says, "this check is only made out for $100."
"That's right," replies the man. "I charged you $250 for sleeping with my wife."
"What! I didn't sleep with your wife!" exclaims the manager.
"Well," the man replies, "she was here, and you could have."
The room was full of pregnant women and their partners, and the Lamaze class was in full swing. The instructor was teaching the women how to breathe properly, along with informing the men how to give the necessary assurances at this stage of the plan.
The teacher then announced, "Ladies, exercise is good for you. Walking is especially beneficial. And, gentlemen, it wouldn't hurt you to take the time to go walking with your partner!"
The room really got quiet. Finally, a man in the middle of the group raised his hand. "Yes?" replied the teacher. "Is it alright if she carries a golf bag while we walk?"
but is still fat.
SKIL SAW:
BELT SANDER:
WIRE WHEEL:
'Oh ****'.
DRILL PRESS:
Channel Locks:
HACKSAW:
VICE-GRIPS:
OXYACETYLENE TORCH:
TABLE SAW:
BAND SAW:
PRY BAR:
PVC PIPE CUTTER:
HAMMER:
UTILITY KNIFE:
lisa'69t-top (10-20-2017)
Crowd Plow For Now
Hurricane leftover Meme's
Kerrmudgeon (10-20-2017)
Crowd Plow For Now
Who goes to a library? Snapchat comments on books....
Crowd Plow For Now
OK, here are the weird ones seen this week....
The following 2 users liked this post by out2kayak:
Kerrmudgeon (10-20-2017),
MAD IN NC (10-19-2017)
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
'Morning everyone!
this sent to me from Billy Schmitt......
MONDAY
The mother of a 17-year-old girl was concerned that her daughter was having sex.
Worried the girl might become pregnant and adversely impact the family’s status, she consulted the family doctor.
The doctor told her that teenagers today were very willful and any attempt to stop the girl would probably result in rebellion. He then told her to arrange for her daughter to be put on birth control and until then, talk to her and give her a box of condoms.
Later that evening, as her daughter was preparing for a date, the mother told her about the situation and handed her a box of condoms.
The girl burst out laughing and reached over to hug her mother, saying,
“Oh Mom! You don't have to worry about that! I'm dating Susan!”
TUESDAY
A man went to church one day and afterward he stopped to shake the preacher's hand. He said, “Preacher, I’ll tell you, that was a damned fine sermon. Damned good!”
The preacher said, “Thank you sir, but I'd rather you didn't use profanity.”
The man said, “I was so damned impressed with that sermon I put five thousand dollars in the offering plate!”
The preacher said, “No ****?”
WEDNESDAY
Brenda and Steve took their six-year-old son to the doctor. With some hesitation, they explained that although their little angel appeared to be in good health, they were concerned about his rather small *****.
After examining the child, the doctor confidently declared, “Just feed him pancakes. That should solve the problem.”
The next morning when the boy arrived at breakfast, there was a large stack of warm pancakes in the middle of the table
“Gee, Mom,” he exclaimed, “for me?”
“Just take two,” Brenda replied. “The rest are for your father”
THURSDAY
One night, an 87-year-old woman came home from Bingo to find her
92-year-old husband in bed with another woman. She became violent and ended up pushing him off the balcony of their 20th floor apartment, killing him instantly.
Brought before the court on the charge of murder, she was asked if she had anything to say in her own defence.
“Your Honour,” she began coolly, “I figured that at 92, if he could screw,he could fly.”
FRIDAY
A Doctor was addressing a large audience in Tampa ...
“The material we put into our stomachs is enough to have killed most of us sitting here, years ago.
Red meat is awful. Soft drinks corrode your stomach lining. Chinese food is loaded with MSG.
High fat diets can be disastrous, and none of us realizes the long-term harm caused by the germs in our drinking water. However, there is one thing that’s the most dangerous of all and we all have eaten, or will eat it.
Can anyone here tell me what food it is that causes the most grief and suffering for years after eating it?”
After several seconds of quiet, a 75-year-old man in the front row raised his hand, and softly said, “Wedding Cake.”
SATURDAY
Bob, a 70-year-old, extremely wealthy widower, shows up at the Country Club with a breathtakingly beautiful and very sexy 25-year-old blonde-haired woman who knocks everyone's socks off with her youthful sex appeal and charm and who hangs over Bob’s arm and listens intently to his every word.
His buddies at the club are all aghast. At their very first chance, they corner him and ask, “Bob, how’d you get the trophy girlfriend?” Bob replied, “Girlfriend? She's my wife!” They’re knocked over, but continue to ask: “So, how'd you persuade her to marry you?” “I lied about my age,” Bob replied. “What? Did you tell her you were only 50?”
Bob smiled and said, “No, I told her I was 90.”
SUNDAY
Groups of Americans were traveling by tour bus through Switzerland .As they stopped at a cheese farm, a young guide led them through the process of cheese making, explaining that goat's milk was used. She showed the group a lovely hillside where many goats were grazing.
“These,” she explained, “are the older goats put out to pasture when they no longer produce.” She then asked, “What do you do in America with your old goats?”
A spry old gentleman answered, “They send us on bus tours!”
MONDAY
TUESDAY
WEDNESDAY
THURSDAY
FRIDAY
SATURDAY
SUNDAY
A farmer
......... in Eastern Arkansas had five female pigs. Times were
hard, so he decided to take them to the county fair and sell them. At the
fair, he met another farmer from nearby Missouri who owned five male pigs.
After talking a bit, they decided to mate the pigs and split everything 50/50.
The farmers lived sixty miles apart. So they agreed to drive thirty miles
each, and find a field in which to let the pigs mate. The first morning, the farmer with
the female pigs got up at 5 A.M., loaded the pigs into the family station wagon, which
was the only vehicle he had, and drove the thirty miles.
While the pigs were mating, he asked the other farmer, "How will I know
if they are pregnant?" The other farmer replied, "If they're lying in the
grass in the morning, they're pregnant. If they're in the mud, they're not."
The next morning the pigs were rolling in the mud. So he hosed them off,
loaded them into the family station wagon again and proceeded to try
again. This continued each morning for more than a week.
The next Morning he was too tired to get out of bed. He called to his
wife, "Honey, please look outside and tell me whether the pigs are in the
mud or in the grass."
"Neither, "yelled his wife, "they're in the station wagon and one of them
is honking the horn."
Playing Your Age.....
A lady is having a bad day at the roulette tables in Vegas. She's down to her last $50. Exasperated, she exclaims to the whole table, 'What rotten luck I've had today! What in the world should I do now?'
A man standing next to her suggests, 'I don't know, why don't you play your age?'
He walks away, but moments later, his attention is grabbed by a great commotion at the roulette table. Maybe she won! He rushes back to the table and pushes his way through the crowd. The lady is lying limp on the floor, with the table operator kneeling over her. The man is stunned. He asks, 'What happened? Is she all right?'
The operator replies, 'I don't know. She put all her money on 36, and when 47 came up she just fainted!'
A witness was called to stand to testify about a head-on automobile collision.
"Whose fault was this accident?" the lawyer asked.
"As near as I could tell," replied the witness, "they hit each other at about the same time."
Ponderings Collection 34
Whose cruel idea was it for the word "lisp" to have an "s" in it?
Since light travels faster than sound, isn't that why some people appear bright until you hear them speak?
How come abbreviated is such a long word?
If it's zero degrees outside today and it's supposed to be twice as cold tomorrow, how cold is it going to be?
Since Americans throw rice at weddings, do Asians throw hamburgers?
Why are they called apartments, when they're all stuck together?
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
If a tree falls in the forest and no one is around to see it, do the other trees make fun of it?
When two airplanes almost collide why do they call it a near miss?? It sounds like a near hit to me!!
Do fish get cramps after eating?
Brother -in-law
A man suffered a heart attack and had by-pass surgery. He awakened to find himself in the care of nuns at a Catholic hospital.
As he was recovering, a nun asked him how he was going to pay the bill.
He replied in a raspy voice, "No health insurance."
The nun asked if he has money in the bank.
He replied "No money in the bank."
The nun asked " Do you have a relative who could help you?"
He said "Just a spinster sister who is a nun."
The nun, slightly preturbed, said "Nuns are not spinsters! Nuns are married to God."
The patient replied, "Then send the bill to my brother-in-law!"
Brother -in-law
Received 1,123 Likes
How does Moses make tea? Hebrews it.
Venison for dinner again? Oh deer!
A cartoonist was found dead in his home. Details are sketchy.
I used to be a banker, but then I lost interest.
Haunted French pancakes give me the crêpes.
England has no kidney bank, but it does have a Liverpool.
I tried to catch some fog, but I mist.
They told me I had type-A blood, but it was a Typo.
I changed my iPod's name to Titanic. It's syncing now.
Jokes about German sausage are the wurst.
I know a guy who's addicted to brake fluid, but he says he can stop any time.
I stayed up all night to see where the sun went, and then it dawned on me.
This girl said she recognized me from the vegetarian club, but I’m sure I'd never met herbivore.
When chemists die, they barium.
I'm reading a book about anti-gravity. I just can't put it down.
I did a theatrical performance about puns. It was a play on words.
Why were the Indians here first? They had reservations.
I didn't like my beard at first. Then it grew on me.
Did you hear about the cross-eyed teacher who lost her job because she couldn't control her pupils?
When you get a bladder infection, urine trouble.
Broken pencils are pointless.
What do you call a dinosaur with an extensive vocabulary? A thesaurus.
I dropped out of communism class because of lousy Marx.
All the toilets in New York's police stations have been stolen. The police have nothing to go on.
I got a job at a bakery because I kneaded dough.
Velcro - what a rip off!
Don’t worry about old age; it doesn’t last.
Kerrmudgeon (10-21-2017)
Hmmm, this one is missing "00."
Time for bed.....see y'all in church.
Three women were sitting around throwing back a few drinks and talking about their sex lives. Karen said, “I call my husband the dentist because nobody can drill like he does.” Joanne giggled and confessed, “I call my husband the miner, because of his incredible shaft.”
Kathy quietly sipped her whiskey until Joanne finally asked, “Well, what do you call your boyfriend?” Kathy frowned and said, “The postman.” Looking puzzeled Joanne asked, ”Why the postman?”
“Because… he always delivers late and half the time it’s in the wrong box.”
A tourist from Bulgaria visits the United States on his first overseas trip. Upon arrival at the Immigration desk, he is visibly puzzled filling out his visa application. The immigration officer looks over the man’s shoulder, and sees the tourist trying to write “Twice a week” into the small space labeled “SEX”.
The officer explains “No, no, no… that isn’t what we mean by this question. We are asking ‘Male’ or ‘Female’.”
“Does it matter?” the tourist answers.
In a tiny village lived an old maid. In spite of her old age, she was still a virgin. She was very proud of it. She knew her last days were getting closer, so she told the local undertaker that she wanted the following inscription on her tombstone:
“Born as a virgin, lived as a virgin, died as a virgin.”
Not long after, the old maid died peacefully, and the undertaker told his men what the lady had said. The men went to carve it in, but as the bastards they were, they thought the inscription to be unnecessarily long. They simply wrote “Returned unopened.”
Crowd Plow For Now
Kerrmudgeon (10-22-2017)
Meanwhile in Canada......
A man from Canada went into the fish market to apply for a job. The boss thought to himself, "I'm not hiring that lazy Canadian", so he decided to set a test for the Canadian hoping he wouldn't be able to answer the questions and he'd be able to refuse him the job without getting into an argument. The first question was, "Without using numbers, represent the number 9." Canadian says, "Dat's easy" and proceeds to draw three trees. The boss says, "What in the world is that?" Canadian says, "Tree 'n tree 'n tree makes nine." "Fair enough" says the boss. "Second question, same rules, but represent 99". Canadian stares into space for a while, then makes a smudge on each tree. "Der ya go bye," he says. The boss scratches his head and asks, "How on earth do you get that to represent 99?" Canadian answers, "Each tree is dirty now, so it's dirty tree 'n dirty tree 'n dirty tree - dat 99." The boss is getting worried he's going to have to hire the newf so he says, "All right, question number 3. Same rules again, but this time represent the number 100." Canadian stares into space again, then he shouts, "I got it!" He makes a little mark at the base of each tree and says, "Der ya go sir -100." The boss looks at Canadian's attempt and thinks, "Ha! got him this time." He then tells him, "Go on, Canadian, you must be crazy if you think that represents a 100." Canadian leans forward and points to the little marks at the tree bases and says, "A little dog comes along and craps near the base of each tree, so now ya got dirty tree an' a turd, dirty tree an' a turd, and dirty tree an' a turd, which makes 100. When do I start me job?"
MAD IN NC (10-23-2017)
After38Years (10-22-2017)
Crowd Plow For Now
