warped holley metering blocks
Received 1,919 Likes
How badly warped are they/is it?
If it's only a few thousands, sanding them on a flat surface may suffice.
If it's more than a few thousands, I'm not sure.
Received 3,043 Likes
St. Jude Donor '05
interesting...op Holley has a rebuild service bet they could get it right
Received 1,843 Likes
Which way is it?
The original issue is that when the body is warped, the power valve well area isn't sealed and under vacuum, it pulls fuel over through the accelerator pump passage in it's center. That causes the engine to run way rich.
I've patched these up in an emergency by using two gaskets instead of one. I did that to a friends 66 for a temporary fix but it lasted for 15 years that way.
I've also installed the metering body backwards with a small block of wood in the center between it and the main body. By slowly/gently tightening the bowl screws, you can bend the body back to it's original shape.
I remember a company years ago that made a metering body gasket with a small "O" ring in the center to seal the accel pump transfer passage. I've never used one but I suppose that it might work.
All the warped ones must have gotten fixed. That used to be a big hiter around here a couple years ago. Everybody had a Holley that wouldn't run right.
Biggest thing I ever saw wrong with a Holley was the guy working on it. The carb would sit dry for awhile and the gaskets would dry up. Then along comes Harry Hamfist with his giant screwdriver and cranks the screws down to stop the leak and bends the metering block instead of installing new gaskets or letting the old ones swell back up.
There may be other reasons. I think this was the main culprit.
Another issue was the thin cork gaskets that Holley originally used. Now the current gaskets are some new slightly thicker material that doesn't squish as easily.
Holley shows the bowl screw torque as 20 INCH lbs.
I think over the years, I used about ten Holleys. Never had a new one but all of them were near new or otherwise unmolested except by me.
Never had a one of them run bad or show signs of metering block warpage. They still sitting on the shelf awaiting new gaskets, and then ready to put on an engine without fiddling with smashing the part in a press.
I never owned one new enough to have the hex screws, only the slot head screws but I often wondered how Harry would react with the hex screws when he saw a leak..
The new Holley metering blocks have a reinforcement that's much better keeping them flat.
With some selected support pieces, squeezing gently in a vise should work. Then again, it it's only out a few thousandths, new gaskets should seal well enough.
