Chevy Small Block Serpentine Accessory drive with A/C
I have been looking at serpentine accessory drive belt systems. Some are IMO too flashy and or too expensive. The GM setup I like and I notice it tucks the alternator into the front more, the power steering pump is about where it is already at, and the AC compressor is like the Alternator pushed forward and tucked in tighter to the block.
Anyone running this? Any problems with the way it fits in the C3 engine bay?
My goal is to have a reliable, strong running Vette that I am not in the least bit afraid to jump in and take a 2000 mile round trip in. The serpentine belt seems to be a better and more reliable option.
Example: http://www.gmperformancemotor.com/parts/12497698.html
looks great, but I woulsd not be afraid to take original belts driven car on a 2000 mile trip as it is. are you having problems with the existing system?? maybe something is not alinged correctly?
Use one from a late 80s early 90s Camaro/firebird, I think mine is from a 1990 Camaro, got it on ebay for around 100$. The ones from the trucks sit to high. I now have the A/C compressor on, everything works great, very easy to do.
LuckySeventySeven (10-22-2017)
Received 3,043 Likes
St. Jude Donor '05
new gm stuff oughta last pretty well, imo its worth it long term..alt should be better or have room for a high output if you want.
Ill take a true serpentine with a tensioner any day over the old Vbelts. Doesnt look as pretty but wont toss a belt suddenly either
Good to know. And I see you are running an electric fan also? I believe I will also go that route.
It's a nice Vette for the money. But the previous work on it was pretty shoddy. Yes the alignment is a little off, washers, different bolts, spacers all over the place. Rather than tweek it endlessly, Id rather bite the bullet and just replace with the serpentine setup. I am fixing the AC now (in no hurry) and was surprised to find out how difficult it was to move all the stuff out of the way and get to the blower motor. That sort of stuff I do not want to do twice. So a lot of stuff is getting replaced.
I bought that exact kit and I am currently restoring the engine bay. The bolts do line up and fit on the engine block. I think the only issue you might have is the fan shroud if you don’t have electric fans. I haven’t put the motor back in the car yet because the parts are getting powder coated. Everywhere I read on the forum said that the kit works great that’s why I went with it. The only thing I didn’t check was the fitment of the stock radiator hoses. If you’re interested I have a used set of that whole kit. Every nut and bolt and accessories that came off a camaro. Just needs some cleaning up. PM me if interested.
St. Jude Donor '05
know of guy that parts out c4s if you want his info pm me
88-91 vette is the system you want/need....uses later compressor and so to get belts made....180 bux here in FLORIDA some time ago....
you really do not want an R4 comp, and the old A6 is just flat out a boat anchor meant for 18 wheelers these daze....
So I need to lookup the AC compressor used in the late 80s then. Just going by the looks of it my current compressor is an R4 style.
Truck Serpentine
I'm currently running the truck setup on my 78. I liked that it kept all accessories in the correct places. Got the entire setup for $75 including pulleys. For the water pump and tensioner, you can ask for 95 suburban parts. For the fan, I went with a 93 Mustang V8. It's clutched and plastic with lots of blades. A lot quieter than stock steel. Fan shroud can be trimmed so fan can stick out recommended inch or so. I kept the R4 compressor. There's a company that makes Sanden adaptor brackets that I'll be upgrading to eventually. I got a random rad hose though. Not sure what it's off of, but I went to the back and got a long curved one to go around alternator since tensioner blocks center. I do not know if pre 74 hoods will accept the height of this setup though. Keep that in mind. I used to run a $40 electric fan on my 100 eBay aluminum rad lol. Never had any issues, but I'm paranoid and feared I was pushing my luck so I went mechanical. Not sure if I covered anything but I'm in a bit of a hurry at the moment.
2017 C3 of Year Finalist
I just changed the belts in my 71 as they were old and squeaqed a bit but otherwise if everything is aligned then no problems at all!
And very easy to maintain/adjust/change!
