Trailing arm shims after upgrade: shave or leave space?
Putting my rear suspension back together after several upgrades, mostly poly bushings, but also adjustable strut rods and a set of global West trailing arms.
Now I'm still missing the shims to completely fill the outer side of the t-arm. Is it wise to leave it that way? I could grind down the thicker shims I do have.
Nearest alignment shop willing to work on older cars is a half hour freeway drive away. So I'm wondering if I should not do a manual alignment anyway?
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,202 Likes
Royal Canadian Navy
You MUST fill the gap with shims to make the car driveable. Grind down the thicker shims if thats what you need to do to fill that gap You could set the toe yourself and camber. Lots of diy info on this.
Do yourself a favor and take shims with you. These newer shops don't keep shims for our trailing arms. I've found that purchasing shims prior to the trip to the alignment shop works best. The mechanics will appreciate it as well.
One more question: how tight a fit should this be?
I've ground them down enough to hammer them in, but maybe they should be "tap in" or even "push in"?
And thanks for the tip on bringing shims, will do!
Dementer sole survivor
Received 6,431 Likes
2016 C3 of Year Finalist
mine tapped in. You dont want them to bind
My shims are pretty snug. This alignment is not difficult to diy. There's videos. Pull the brake discs off and bolt them on backwards, support the discs with floor jacks positioned so the jack wheels allow side to side movement, pull some strings, measure carefully and move shims around til you got it. I've got mine exact (within' inches) No, mine are pretty daggone good using the string method.
They should be snug with the bolt loose.
I would recommend Stainless Steel shims if you plan on keeping the car.
They do come in packs with an assortment of thicknesses.
worship79 (11-25-2017)
Thanks, I managed with some grinding
Ordered new shims to take with me to the shop.
