C6 Corvette ZR1 & Z06 General info about GMs Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Auto Blip for you C6 Zo6/ZR1.........
Old 11-20-2017, 09:12 AM
RDP Store
Supporting Vendor
RDP Store's Avatar
Default Auto Blip for you C6 Zo6/ZR1.........
RDP Store gives two thumbs up to the AUTO-BLiP. IT is a really slick unit and very effective on the track. It is a perfect addition to the C6 platform. Check it out, don't be scared.
It is a new patent pending electronic device that will automatically blip (open) the throttle when downshifting gears on an automobile equipped with a manual transmission and an electronic accelerator pedal system. AUTO-BLiP works by monitoring your automobile’s accelerator pedal position sensor (TPPS), brake pedal, and clutch pedal, and only blips the throttle when both brake and clutch pedals are pressed simultaneously. AUTO-BLiP reduces mechanical wear and tear on manual transmissions, improves vehicle stability when downshifting gears, and eliminates the need for the heel-and-toe driving technique.
Use the Promo code of blipsav
http://www.rdpstore.com/p-9334-auto-...ownshifts.aspx
Old 11-20-2017, 10:43 AM
mirage2991
mirage2991's Avatar
link doesn't work
The parameters dictionary contains a null entry for parameter 'id' of non-nullable type 'System.Int32' for method 'System.Web.Mvc.ActionResult Detail(Int32, System.String, System.Nullable`1[System.Int32])' in 'AspDotNetStorefront.Controllers.Product Controller'. An optional parameter must be a reference type, a nullable type, or be declared as an optional parameter.
Parameter name: parameters
08VelocityZ (07-20-2021)
Old 11-20-2017, 10:46 AM
RDP Store
Supporting Vendor
RDP Store's Avatar
Lets try this kind sir...........
http://www.rdpstore.com/p-9334-auto-...auto-blip.aspx
Originally Posted by mirage2991
link doesn't work
Old 11-20-2017, 07:58 PM
Les
Les's Avatar
I just used mine yesterday on my favorite back road and I love it. Can't wait to hit the track in the spring!
RDP Store (11-20-2017)
Old 11-20-2017, 10:54 PM
zeeohspit
zeeohspit's Avatar
Wow I️ need this!!!
RDP Store (11-21-2017)
Old 11-21-2017, 09:56 AM
RDP Store
Supporting Vendor
RDP Store's Avatar
Group Buy right now on AutoBlip till Monday at Midnight........$335.oo shipped to your door with 7 or more orders...........lets get that list going, once I see 7 or more interest I will post up the promo code to save..........in the order notes please put your year and sub model Corvette.....I will be placing AutoBlip orders on Friday at 3pm
Old 11-21-2017, 10:31 AM
fuggles
fuggles's Avatar
I'm in for the group buy.
Old 11-21-2017, 10:09 PM
JimsCorvettes
Support Corvetteforum!
JimsCorvettes's Avatar
So, I will be buying a ZR1 in (early) 2018. Not sure of the year yet but will this fit all years for the C6 ZR1 production? 2009-2013?
Old 11-21-2017, 10:14 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
Hello Sir, yes the Auto Blip will be perfect for your C6 ZR1 no matter the year
Old 11-22-2017, 05:21 AM
JimsCorvettes
Default I am in
Excellent (I see that now our your link).
I am in.
Jim
RDP Store (11-22-2017)
Old 11-22-2017, 10:26 AM
RDP Store
Supporting Vendor
RDP Store's Avatar
I am in.
Jim
Perfect Sir...........well we got three guys in we need four more by Monday for the group pricing........spread the word
Old 11-22-2017, 11:33 AM
Mean 69
Mean 69's Avatar
Very clever, I'm in for a 07 Z06.
Old 11-22-2017, 11:57 AM
RDP Store
Supporting Vendor
RDP Store's Avatar
Awesome.......this is four......three more too go, spread the word
Old 11-23-2017, 10:27 AM
7007vette
7007vette's Avatar
Ill take one for an 07 ZO6
RDP Store (11-23-2017)
Old 11-24-2017, 06:22 AM
RDP Store
Supporting Vendor
RDP Store's Avatar
Ok Guys...........we are ready to rock and roll......I contacted Auto-Blip he has units there staged and ready to ship out.....I will be placing our first round of Black Friday weekend orders tonight and the second and last order for Auto-Blip special pricing on Monday night.....then we are back to normal pricing.....so below is the promo code and link for your ease of use.....please please put your year and sub model of Corvette in our order notes....also this promo code is to only be used solo, do not use with any other promo codes.
Promo Code: blipsav
Old 11-25-2017, 10:39 PM
ROADRACER_
ROADRACER_'s Avatar
How is this unit installed? Is this a simple DYI installation?
Old 11-26-2017, 01:08 AM
Les
Les's Avatar
That depends on your skill level and what you consider simple. Mordeth is a great contributor to the forum and I used his tutorial to help with my installation- check Post #28 of the link below. Between that, the provided instructions, and the great support from Auto Blip it wasn't bad at all. I removed my drivers seat to gain better access to below the dash. I doubt I could have done it without doing that. I have mine mounted exactly where Mordeth put his, which makes it very easy to turn on/off and to adjust the settings. You'll need to drill a small hole to run the cable through- make sure you run it through before making all the connections. You'll see what I mean. It's a great little unit.
Here you go- https://www.corvetteforum.com/forums...er-mods-2.html
To Auto Blip for you C6 Zo6/ZR1.........
Old 11-26-2017, 09:03 AM
RDP Store
Supporting Vendor
RDP Store's Avatar
IT is a very simple install....just need to be a bit flexable....below are the install instructions
http://www.auto-blip.com/pdf/2008_20...vette_v1_7.pdf
Old 11-26-2017, 08:48 PM
JimsCorvettes
Just placed my order!
Order Number: 108136
Needs to fit a 2009-2013 ZR1.
Thanks!
RDP Store (11-26-2017)
Old 11-26-2017, 08:50 PM
RDP Store
Supporting Vendor
RDP Store's Avatar
Thanks!
Perfect Jim..........It was pleasure to deal with you and I will get that going for you tomorrow
Quick Reply: Auto Blip for you C6 Zo6/ZR1.........
