Suggestion Please!
Suggestion Please!
Fellows! Last night when I started my 2008 Z06, I noticed clicking noise in the engine bay. I open the hood and did not noticed anything unusual but sure the clicking noise is there. I decided to take it to the dealer and after several hours of waiting, here comes the bad news. They said I need a new engine!! btw my car only has 16,300 miles on it so I was in shock. Told them that I will take it to different dealership to ask for second opinion. They then told me to wait and they will contact GM and see if they can atleast help out or something because they quoted me for about 19k for engine and labor. I will find out tomorrow what GM response is. Any suggestions guys? FYI: No engine check light or any indications of any problem...I actually drive it to the dealership and did not loose any power or anything binding.
The more input I can get will give me a better idea on what to do next!
Do you have any sort of warranty? If not, I would stop going to dealerships and find a good LS shop near you that can actually diagnose the problem and not just throw a new motor at it.
Agree with Jared. You're in Chandler give Joe Cordes a call he owns Cordes performance racing in mesa. He will het you squared away. Avoid stealerships at all cost unless warranty
Hard to believe you would need a new motor if you drove it just fine and no fluids were leaking. Sounds like that dealership is trying to get money out of you and you should take it elsewhere like an actual shop that deals with LS motors. More than likely you will need to get the valve guides replaced or possibly completely new heads which wont be anywhere near $19k. Im with SpnkbnkZ06 I dont deal with stealerships, I did heads and cam myself, but had to take the heads to a local shop to get the valve guides replaced and new valves of course.
First of all, avoid dealerships unless you are under warranty.
Have it towed to CPR for inspection. Sounds like a lifter/cam going bad, which maybe able to be fixed without a new motor. Still not cheap.
Should have heads inspected and dealt with at same time since most of that has to come off.
St. Jude Donor '09-'11
Thanks guys for all the suggestions!!
Here is the update I got this morning.
They contacted GM and they are willing to participate with the repair.
It will cost me 13k out of pocket
GM only requires engine to be take apart to the point of failure and take pictures...also provide the history of repairs/oil changes done with the car prior.
What do you think guys? should I go for it?
Thanks Much!
Thanks Much!
Thanks Much!
Thanks Much!
I was thinking failed lifter as well...but that shouldn't wipe out a complete motor. Get your car out of there and towed to CPR like everyone has recommended.
