Help: Vert Top Leaking Hydraulic Fluid
Just bought my 2016 Vert 7900 miles. About the 4th time I have dropped the top and it started spraying hydraulic fluid all over the passenger side seat. Anyone have this problem or have an idea what happened? Very frustrating...just got the car and already problems. Thanks
Pisswilly (11-23-2017)
Received 3,117 Likes
Finalist 2020 C7 of the Year -- Unmodified
Another thing to think about for us Vert owners. Bring it to the dealer and let them deal with it and hope it didn't get on the rug. Honestly first time I heard of this.
I think if you operate your Top when moving it will twist the Top more than you need too.Just thinking this could cause anything to loosen,break or other issue's in time?
Manual sez it's ok to operate the Top up to 35 MPH.No Thanks,I'll stop
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
I am with you on this. Fastest I chosen to do it is around 20 mph. Not going to chance anything faster.
DALE#3 (11-23-2017)
These cars feel everything.Any,will transfer to that frame of the Top.Why have additional shifting if not really needed.Just thinking in the long haul.
I never put mine down while I am driving.
My 2017 had this happen (passenger side). They said it was an improperly routed hydraulic line and it was fixed under warranty. The seat cleaned up fine. The issue I now have is that it sounds like there's an air leak from behind the passenger's head. I've taken it in three times and they just say "that's normal it's a convertible". I told them it's not normal, it wasn't delivered like this from the factory, and I'd like it fixed...it certainly wasn't like this when I brought it to you to fix the leak. The dealer still says there's nothing wrong so the fight Continues...
NCM Lifetime Member
True this. I don't make a habit out of it. Only if the light turns green and I am close to the end of the cycle.
