E-brake sticking after sitting
Old 11-25-2017, 01:49 PM
JamieJT
JamieJT's Avatar
Default E-brake sticking after sitting
I noticed the e-brake sticking after the car has been parked for a while has anyone else had this problem ? It sounds like its still engaged when you start to go
Old 11-25-2017, 02:19 PM
Foosh
Foosh's Avatar
Received 16,668 Likes on 8,311 Posts
It can happen, particularly if you put the car away with the rotors wet, pads can stick to them. It's no big deal. The cure is to apply enough power to break them lose and then apply the brakes a few times to clean off the rotors.
JamieJT (11-28-2017)
Old 11-25-2017, 02:44 PM
Maxpowers
Maxpowers's Avatar
Received 2,729 Likes on 1,829 Posts
Yup. It's likey a bit of rust due to the iron rotors. They are iron due it's superior heat dissipiating qualities. Burn off the water before you park.
Old 11-27-2017, 12:03 AM
jabeasley1
jabeasley1's Avatar
Concur on wet rotors. In the beginning, I would wash my car then pull it forward in the garage. A few hours later, I would try to leave and my E-brake would be stuck. I would have to throttle through the gas to break it free. Now, I just pull it forward, place it in gear, then not use the E-brake (but only after washing the car). Hope this helps
Old 11-27-2017, 12:22 AM
Blackbird13
Blackbird13's Avatar
The ebrake sticking issue I experienced was really annoying, but it completely disappeared when I changed to Carbotech brake pads
Old 11-27-2017, 10:54 AM
lavla
lavla's Avatar
The C7 E-Brake is miles ahead of the C6 brake. That said, I use it when parking for a short time but always put the car in reverse while parking (M7). When parking for an extended period, though, just put the car in reverse.
Old 11-27-2017, 11:34 AM
Skid Row Joe
Skid Row Joe's Avatar
Received 4,001 Likes on 2,888 Posts
lavla: Is there some sort of advantage(s) to parking with your M7 in Reverse ?
Old 11-27-2017, 11:35 AM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes on 2,065 Posts
2015 C7 of the Year Finalist
You don't need to set the E-Brake. Similar to me parking in "Park" in my garage, no E-Brake.
Elmer
The following 2 users liked this post by eboggs_jkvl:
lavla (11-27-2017), Skid Row Joe (11-27-2017)
Old 11-27-2017, 12:27 PM
davepl
davepl's Avatar
Received 1,500 Likes on 987 Posts
It -used- to be more conservative about battery usage and not drain the battery as fast, back in the C5 days, or something like that.
I've not heard that it actually makes a difference on the C7.
For parking, you just want the steepest gear, and either first or reverse will work. I'll defer to the next pedant to go look up which one is actually steeper, I'm not sure, but it doesn't really matter.
Old 11-27-2017, 12:41 PM
defaria
defaria's Avatar
Received 1,203 Likes on 732 Posts
Elmer
Same would be true if you park it in 1, 2, 3, 4, 5, 6 or 7th...
If you don't set the e-brake then when you return and start your car the memory seat position will not engage.
I've experienced times when the e-brake was stuck and you could not unstick it merely by hammering on the gas, rather you needed to step on the brake and push the e-brake down.
Old 11-27-2017, 01:02 PM
Foosh
Foosh's Avatar
Parking in reverse on the C7 M7 makes no difference. It did on the C6 because it prevented battery drain, so it's old habit w/ many Vette vets.
Old 11-27-2017, 01:35 PM
eboggs_jkvl
It's also in the Owner's Manual as a step in the shut down of cars equipped with the M7 transmission.
9-22 Driving and Operating
Stopping the Engine
If the vehicle has an automatic
transmission, move the shift lever to
P (Park) and press and hold the
ENGINE START/STOP button on
the instrument panel, until the
engine shuts off. If the shift lever is
not in P (Park), the engine shuts off
and the vehicle goes into the
accessory mode. The DIC displays
SHIFT TO PARK. Once the shift
lever is moved to P (Park), the
vehicle turns off. If the vehicle has a
manual transmission, move the shift
lever to R (Reverse) and set the
parking brake after turning off the
engine by pressing and holding the
ENGINE START/STOP button.
Elmer
Old 11-27-2017, 01:48 PM
Foosh
Foosh's Avatar
Yes, that's the traditional way of being max safe against a roll-away, so it remains in the manual. However, I've never heard of an e-brake failing.
I was talking more about the battery drain issues on previous gens, which parking in reverse helped mitigate.
Old 11-27-2017, 03:22 PM
defaria
defaria's Avatar
I don't understand. If I park it and leave the gear in 1st are you saying it then drains the battery. But if I park it and leave the gear in reverse is doesn't drain the battery?!?
Old 11-27-2017, 03:23 PM
JerryU
E-Ray, 3LZ, ZER, LIFT
Support Corvetteforum!
JerryU's Avatar
Received 9,625 Likes on 6,629 Posts
E-Brake is operated by brake shoes in drums on the rear wheel rotor center hubs! However could still be caused by pads sticking to rotors but that has nothing to do with E-Brake.
However on my 2014 I found the “automatic release” by driving was inconsistent and would not release! Stopped using in 2014.
Have not tried with my Grand Sport. When backing out of the garbage, IF I forget to release it by pushing the button down it try’s to stall the engine. I stop, depress the clutch and release with the button.
On my 2014 I tried to force it and it popped with a loud noise! The E-Brake engaged light stayed on the dash for 15 miles all the way into town! Light went off when I restarted the car. Not worth trying again!
Old 11-27-2017, 03:25 PM
Foosh
Foosh's Avatar
The e-brake, auto-release works well on my 2014, every time I try it, which is fairly often.
Old 11-27-2017, 03:26 PM
JerryU
JerryU's Avatar
As Foosh said he was referring to an old model Vette. No drain in the C7.
To E-brake sticking after sitting
Old 11-27-2017, 03:28 PM
JerryU
JerryU's Avatar
Yep, others have said the same. Did not for me and I tested in 1st as well. Worked less than half the time. Looked for and adjustment in my Service Manual. Found none. Easy to push the lever down!
Old 11-27-2017, 03:29 PM
Foosh
Foosh's Avatar
No, what I am saying is that it doesn't matter on the C7 M7. It did matter on the C6 M6, which needed to be parked in reverse to prevent battery drain.
Old 11-27-2017, 03:42 PM
eboggs_jkvl
NO NO NO
The C5s had the software programmed such that it was MANDATORY to put the manual transmission into Reverse and the steps to shut down were laid in stone. If you failed to follow the procedure exactly or if you just left the stick in a gear other than reverse or in neutral, the electronics would not shut down properly and it would rape your battery quickly and you'd end up with a dead battery overnight. GM updated the software eventually and the reverse gear thing was removed and the batteries were much happier not to mention the owners. It did not happen in the C6 nor the C7.
In my flat garage, I'd leave it in neutral and set the brake. With my current car, I just put it in "P" and leave it. The only time I use the E-Brake is to park on a hill so as not to leave the hill pressure slammed on the tranny.
Elmer
Quick Reply: E-brake sticking after sitting
