Sponsored by: GEM Motorsports
How to make an ATS-V sound like a Z06
Old 12-01-2017, 03:33 PM
sales @ WXM
sales @ WXM's Avatar
Default How to make an ATS-V sound like a Z06
I know this isn't a Z06 but I think it's relative enough to be in the section.
After one of our clients reached over 600rwhp on his ATS-V coupe, he has had some fun with it for around 6 months, and now he has came to the conclusion there is no replacement for displacement. We placed the order for the LT4 today, and we are now preparing to do the first LT4 conversion on an ATS-V Coupe.
Stay tuned and I will continue adding content to thread as progress continues!
Here are some pictures of our engineer David placing the LT4 inside of the ATS-V CAD model.
Old 12-01-2017, 03:43 PM
Kappa
Kappa's Avatar
Always wondered when someone would give the LT into ATS swap a try. Is the engine bay much different from a Camaro?
Old 12-01-2017, 04:37 PM
Torch Red Z06
Torch Red Z06's Avatar
Why didn’t he just buy a CTS-V to begin with?
Old 12-01-2017, 05:06 PM
pkincy
pkincy's Avatar
Old 12-01-2017, 05:23 PM
Connman
CF Senior Member
Support Corvetteforum!
Connman's Avatar
St. Jude Donor '17
IB4 Move
Old 12-01-2017, 06:06 PM
sales @ WXM
After driving both the ATS-V and the V3 I actually like the size of the ATS-V better. I like the idea of have a smaller "V3 type" coupe, and if you have the money why not?
Old 12-01-2017, 08:14 PM
SharkbyteLT4
SharkbyteLT4's Avatar
what transmission is going to be used for this???
Old 12-01-2017, 08:17 PM
sales @ WXM
I was really hoping for the ZL1 A10 to be the choice, but we decided against modifying the trans tunnel so it will have an A8.
SharkbyteLT4 (12-01-2017)
Old 12-02-2017, 01:38 AM
Poor-sha
Track Rat
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
The lack of a manual trans has kept me out of the V3 CTS-V. Really interested in how this swap would work with a manual.
Old 12-02-2017, 09:21 AM
Kevin Parent
Kevin Parent's Avatar
Where in the world did you get the math for ATS?
And in .prt format as I see he is using NX.
Old 12-02-2017, 12:24 PM
sales @ WXM
We have a few sources through GM that provided us with the models.
Old 01-10-2018, 10:38 AM
sales @ WXM
They new crate engine LT4 is here. Now its time to start to disassembling it for some upgrades!
Old 01-10-2018, 03:41 PM
Pacembellum
Pacembellum's Avatar
This is such a silly swap. Just get a ZL1 but will be a fun build and sweet outcome!
Old 01-15-2018, 05:57 PM
sales @ WXM
Here are few pictures that were taken during the heads/cam install. I also gave a list of the parts we used, and a brief explanation of why we chose them.
-Weapon-X Stage-3 PD Blower Cam w/ +32% Fuel Lobe
Since the LT4 is going to be backed by a 6 speed manual transmission we were able to run our Stage-3 Camshaft to maximize the efficiency of the engine making more power with less boost. This Cam will also pair very well with the Whipple 2.9 if/when our client decides to add it in the future.
Weapon-X Stage-2 CNC ported heads with hand finish smoothing
Again, this even further optimizes the engines efficiency allowing for more airflow through the head. The more air you can get into the cylinder, then out equally as fast, the more power the engine will make. (As long as you have the fuel to support it.) Another small benefit is ported heads usually dissipate better. Having a head that allows more flow both in and out decreases manifold pressure generating less heat pre intake valve, at the same time it is allowing the hot exhaust gases escape more freely shedding heat on the exhaust side too.
-PAC .660 Dual Valve Springs w/ Titanium Retainers
When adding an aftermarket camshaft with increased lift, or a more aggressive lobe ramp a stiffer valve spring is required for numerous reasons; to prevent valve float, spring breakage, and valve bounce back off of the seat.
-5/16" 4130 Chromoly Hardened Pushrods
A more robust pushrod is less likely to bend or have any flex at high rpm.
-GM Performance LS7 Lifters
Although we have not seen an LTX cylinder deactivation lifter fail, it is out of good practice that we learned in the LS days to replace them with normal hydraulic lifters when increasing the engines power output. The increased cam lobe lift, and higher valve spring rate puts also put more stress on the lifters which is why we replace them with upgraded one.
-Texas Speed 0 Degree Cam Phaser Limiter
This eliminates any unwanted timing advancement allowed by the VVT camshaft phaser under load, high horsepower, or any harsh conditions for that matter. Similar to the lifter upgrade, it is another part with mechanical complexity that by adding a TSP 0 degree lockout pin we remove risk of failure.
-C5R Timing Chain
Increased rigidity, less likely to stretch.
-ARP Head Stud Kit
With added cylinder pressure from increased boost/horsepower the ARP studs do a better job at clamping the cylinder head to the engine block. The stud and nut type fastener also reduces the risk of pulling the threads out of the engine block compared the basic, or even upgraded head bolt.
-GM Performance LT4 Head Gaskets
Whenever using an MLS (Multi Layered Steel) head gasket and removing the cylinder head the head gasket should be replaced, even on a brand new crate engine like below.
cvp33 (01-21-2018)
Old 01-15-2018, 06:06 PM
Mr. Gizmo
Mr. Gizmo's Avatar
Good stuff. A stock lt4 feels pretty anemic and can use the improvements
Keep us us posted on this caddy.
sales @ WXM (01-16-2018)
Old 01-16-2018, 09:07 PM
DSOMDream
DSOMDream's Avatar
A stock lt4 is anemic. OK John Force. LOL Paul
Old 01-16-2018, 09:30 PM
STL94LT1
STL94LT1's Avatar
To How to make an ATS-V sound like a Z06
Old 01-18-2018, 02:23 AM
mcoomer
mcoomer's Avatar
I know you can wake it up but yeah, I'd have a hard time calling it anemic. Still, interested in seeing how this turns out.
Old 01-18-2018, 09:31 AM
09Z06pj
09Z06pj's Avatar
Received 1,100 Likes on 752 Posts
Old 01-20-2018, 04:06 PM
sales @ WXM
Default Out with the old, in with the new!
We made some more progress on the ATS-V this past week. The 700hp twin turbo LF4 engine was removed, and we now have the LT4 mounted in its place. The install went very smooth, the engine was a direct fit with the exception of the transmission support brace.
The following 2 users liked this post by sales @ WXM:
cvp33 (01-21-2018), KSA Aaron (01-21-2018)
Quick Reply: How to make an ATS-V sound like a Z06
