Procharged FRC Build
Ive been gathering parts for this build for about a year now. Some parts came off my Formula when it was procharged and others are new. My goals are to make 900 or so rwhp and make a fun roll car. Purchased this car in 2013 with 27k miles on it and have driven it everywhere and it now has 130k miles.
This build consists of the following:
1999 A/W FRC
Iron 5.7/k1 rods and crank/wiseco pistons(10.2:1)
Jam cam
Afr heads
Ls6 intake/stock tb
Holley rails/fic1300 injectors/-10 feed -8 return/custom fuel with dual 450’s/e85
Procharger f1a/Innovators west 10 rib balancer/a@a bracket 10 rib/a@a secondary drive/treadstone intercooler/big red bov
Dewitts radiator stock fans
TDP 6060 conversion
McLeod rxt1200
Kooks 2’’ Headers
A couple of weeks ago I got an awesome deal on installing the drivetrain and secondary drive which I cant thank Bad Chad enough as this saved me a lot of time and headaches.
What I have been working on the past couple of days has been fabbing the piping, mounting the intercooler, reworking the factory radiator cradle, and coming up with a shroud that Im going to have bent up out of aluminum.
Im gonna start posting pics now that I actually have some progress to show.
Stock fan shroud trimmed on the passenger side
Stock cradle torn apart to push radiator mount forward about and 1.5"
Radiator now sits below inlet
Mount moved forward
About 2.5" of space between the IC and condenser
Fabbing the piping
1999 A/W FRC
Jam cam
Afr heads
Ls6 intake/stock tb
TDP 6060 conversion
McLeod rxt1200
Kooks 2’’ Headers
Mount moved forward
Fabbing the piping
CorvetteBrent (08-14-2018)
Intercooler mounted and bumper notched
4" from I/C to TB
Clearance between I/C and condenser/radiator hopefully running hot wont be an issue
Bov placement
Simple yet effective brackets
10 rib looking nice
Plenty of space
Question for you boosted fellas. My plan was to run a -12 fitting on the valvecovers to the same peterson breather can I used on my firebird. I bought this pretty cool aluminum windshield wiper reservoir the other day that was being used for methanol. Do you all thing it could serve the purpose of the breather can? I could easily weld to -12 fittings on the side of it. It has some sort of baffling already inside. Only thing I see i would need would be to replace the cap with some kind of filter so it can breathe. Thoughts or input?
This what i used previously
Two -12 fittings can easily be welded on the sides
Replace this cap with a screw in breather
Baffling?
Baffling?
Good luck on your build. I would be a little worried about your crank though. Big power and blowers don't go well with the lower end forged cranks. The added stress makes them flex and take out bearings. I know for sure it happens with compstar cranks. Happened to my car and a few others I know of. Maybe the k1 will do better but I would be worried. If you have time to change it, look into a better crank.
Yeah its Deubel Products. I tried calling them and sending a message through FB with no response. Id like to have the radiator reservoir made.
Edit: Pic for reference
dopefedz (12-13-2017)
those shorter mounts really make a big difference. I may have found a local machine shop to cut the rail down some and retap and cut the oring chamfer Ill find out monday.
Most of my fuel stuff has arrived. Waiting on some flex tube/hose for inside the tank to show up.
also made up my venturi block to feed the passenger tank/siphon pump
Still waiting on a couple items to show up shipping times suck right now. I did manage to mod my rail and fore fitting and now i have a little over an inch of clearance between rail and firewall.
