C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Weight of interior carpet and misc
Old 12-10-2017, 06:04 PM
l98tpi
Max G’s
Support Corvetteforum!
l98tpi's Avatar
Default Weight of interior carpet and misc
I've search various places on this forum and the net and haven't got a clear answer? Has anyone removed their carpet and insulation from their C6z and weighed that material so you know how much it weighs; how much weight was saved by removing?
Old 12-10-2017, 11:20 PM
LMB-Z
LMB-Z's Avatar
I have not, but I would guess less than 10 lbs. Probably more like 5. Just don't eat supper for a couple of days before you go racing if thats what you are after.
"Misc." doesn't weigh anything either
Old 12-11-2017, 12:45 AM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
I think the 06 didn't come with insulation, or so I've read...but was later added in to "civilize" the car a bit in 07 I believe.
Old 12-11-2017, 03:05 AM
meinersk
meinersk's Avatar
06 didn't have the sound deadening which was like 25 lbs or something like that
Old 12-11-2017, 09:06 AM
l98tpi
Max G’s
l98tpi's Avatar
Mine is a 2007. I had seen mention before in post that 50-75lbs could be saved. I didn’t think that number was accurate.
Old 12-11-2017, 01:50 PM
philadd
philadd's Avatar
No way it's that much. I didn't weigh anything, but I've pulled everything out before. I have an '09, and all together (driver and passenger "tubs", behind the seats, and trunk) the carpet and insulation probably weighed around 20 lbs. And I think I might be overestimating.
Now, if you strip everything you can (center consoles, XM module, OnStar module, HVAC equip, etc) you can probably save 50+ lbs in the interior.
To Weight of interior carpet and misc
Quick Reply: [Z06] Weight of interior carpet and misc
