Tired of Hearing My Fob Hit the Ground
Old 12-11-2017, 11:00 AM
felkebg
felkebg's Avatar
Default Tired of Hearing My Fob Hit the Ground
Tried a rubber band but now these. Other solutions? Any vets who can tell me the nomenclature of the can opener get extra points.....
Old 12-11-2017, 11:04 AM
Ramler
Support Corvetteforum!
Ramler's Avatar
It was called a P38
My key fob is not linked to anything and stays safely in my pocket. Never dropped and only pulled it out once to try the auto start.
Vett2017 (12-12-2017)
Old 12-11-2017, 11:09 AM
c54u
c54u's Avatar
FOB jacket
This should fit the C7
https://www.thejacketstore.com/store...Cover-4p72.htm
The following 3 users liked this post by c54u:
Avanti (12-12-2017), dbintegrity (12-12-2017), felkebg (12-12-2017)
Old 12-11-2017, 11:24 AM
Flame Red
Flame Red's Avatar
Received 1,084 Likes on 656 Posts
Originally Posted by c54u
Old 12-11-2017, 11:25 AM
traronf
traronf's Avatar
I have the Cadillac fob holder and it also holds the key in place.
Old 12-11-2017, 12:35 PM
ElGreco53
ElGreco53's Avatar
And the apocryphal story I remember is that the P38 was called that because it took 38 "punches" to open a can of C-rats. I'm guessing they became useless when MRE's were introduced?
Old 12-11-2017, 12:56 PM
LanceVette
LanceVette's Avatar
Your are correct.
ElGreco53 (12-11-2017)
Old 12-11-2017, 01:14 PM
mschuyler
mschuyler's Avatar
Received 3,818 Likes on 1,614 Posts
I've had a P-38 on my key ring since the 1960's, but the FOB is carried separately and never falls out. I don't need to carry keys anymore at all.
Old 12-11-2017, 01:17 PM
curve65
curve65's Avatar
Up, still got one or two floating around.
Old 12-11-2017, 01:28 PM
ElGreco53
ElGreco53's Avatar
Same here, I got P38s stashed everywhere, just in case. Old habits die hard...
Old 12-11-2017, 01:45 PM
ricks327
ricks327's Avatar
Received 1,613 Likes on 901 Posts
Will this jacket work on the convertible top button?
Old 12-11-2017, 01:52 PM
TEXHAWK0
TEXHAWK0's Avatar
I never carry extra keys on a ring with the fob...
I wear jeans a lot and I just tuck the fob in the watch pocket... have never dropped it.
Old 12-11-2017, 02:56 PM
c54u
c54u's Avatar
Yes it should. You just press on the soft silicone for the top up/down.
Old 12-11-2017, 03:18 PM
defaria
defaria's Avatar
Received 1,203 Likes on 732 Posts
My solution is to simply not drop my fob...
The following 2 users liked this post by defaria:
DWS44 (12-12-2017), Perf n Restore (12-11-2017)
Old 12-11-2017, 05:55 PM
georgehafe
georgehafe's Avatar
NCM Ambassador
Cruise-In 1, 2, 6, 8 Veteran
John Wayne
USMC 0802 (12-12-2017)
Old 12-11-2017, 06:30 PM
GTFD2
GTFD2's Avatar
Anyone know why it is called a P38?
Old 12-11-2017, 06:36 PM
mschuyler
mschuyler's Avatar
Defaria, that's not the issue. The issue is that the weight of the key ring itself dislodges the metal cap because it is not well attached. My CTS key fob is made the same way, but detaching the two parts requires a little more force then the Corvette fob. If they'd used the same engineering they did on the Cadillac fobs this wouldn't be a problem. OP is not the first one to complain about this issue.
To Tired of Hearing My Fob Hit the Ground
Old 12-11-2017, 07:47 PM
Red C8 of Jax
Red C8 of Jax's Avatar
Received 1,108 Likes on 748 Posts
At least yours hits the ground. I loose mine and finally had to order an extra fob after I couldn't find Fob A.
Old 12-11-2017, 08:03 PM
SnowyATX
SnowyATX's Avatar
This should work for you. I've had cheap ones that fall apart. I like this one better.
Amazon Amazon
The following 2 users liked this post by SnowyATX:
felkebg (12-12-2017), JamieJT (12-13-2017)
Old 12-11-2017, 08:45 PM
Gearhead Jim
Gearhead Jim's Avatar
Received 2,043 Likes on 1,357 Posts
St. Jude Donor '13
My C6 fob would not release the key, no matter how hard I squeezed the buttons, until one day I pulled hard enough to break the latch. Then it would just fall out.
So I used a Fob Jacket for a couple of years until the dealership found out, got me a new fob and reprogrammed all 3, covered by our GMPP warranty.
The Corvette seems to have gone from Too Tight on the C6 to Too Loose on the C7.
Quick Reply: Tired of Hearing My Fob Hit the Ground
