C7Z E85 Flex Fuel Results!! Check It Out!!!
thesaad (05-08-2019)
I'm Batman..
Pro Mechanic
Billy, these are fantastic results! I have a few questions if you don't mind about running E85 with meth. How exactly does E85 increase the power when meth is already being used? Since meth raises the octane as it is to run increased timing, what is the E85 doing that the meth can't?
Former Vendor
The E85 lowers the IATs a ton and the octane is much higher than 93. I can get away with much higher timing with the e85 without kr showing up. PD blowers seem to love the stuff. Plus the meth is sprayed before the rotors the e85 is sprayed right into the combustion chamber. We see most of these pick up at least 30 hp without changing the timing.
jstewart (01-18-2019)
I'm Batman..
Pro Mechanic
I run dual meth currently (no E85) and peak at about 20* timing. If I ran E85 on top of my meth would you be adding a couple of degrees?
Sorry for all the questions. Just trying to get a handle on how E85+meth is different than running more meth.
Ant
Former Vendor
Its more from the timing. I will not add as much timing with a meth and 93 setup because theres no way to be 100% sure that you are getting meth to all the cylinders evenly. With E85 I know for a fact that all the cylinders are getting even fueling.
All of the above stuff in bold is equally true about meth when run independently already though right? (Lowers IAT, much higher octane to fight detonation, allows much higher timing, etc). Is the primary difference and gain in HP between meth solo vs meth+E85 attributed to it being direct injected instead of atomizing before it gets to the combustion chamber (as in a meth setup)? Or is the gain related to mainly timing?
Ant
Ant
FYREANT (12-21-2017)
Yea the meth /93 tune up was conservative..
not much difference between meth and E85..
nice power!! I agree I would play it safe as well on the meth..
ive been running 93/e85/meth for a couple of years now
Billy@MTI (12-22-2017)
I'm Batman..
Pro Mechanic
Ant
I love running meth and e85. Been using them both for over two years. Best of both worlds.
Received 1,762 Likes
ttt
Billy you guy have got to stop all this crap. I told my self was not going to do nothing to my c7. Was going to keep it 100% stock I shot all of that to ****.
You guys are doing good man really keep it up man. Robert
Former Vendor
Depending on boost level. I stay around 19 on 93/meth
So if I running 20* timing at peak on a dual meth/no E85 setup, would you say my tuner is playing it safe? Or would you say there may be some power left on the table if I switch to like E50 blend with the dual meth? (I realize you may not be able to truly answer that without seeing my tune entirely)
Ant
Ant
Just depends on what the motor likes. Every car is different. I’m flex fuel son on 93/meth my car has 14* in it and when I’m on corn it bumps to 16*. We can go higher if needed but it’s still stock bottom end so keeping it together while I still drive the crap out of it.
I'm Batman..
Pro Mechanic
I'm in the process of looking for a tuner for adding E85 to my tune so was just trying to get an idea if it was worth it or if I simply don't have any improvement to gain from adding it.
Ant
It’s well worth it
