BLOWN MOTOR: Lucky for this guy he still has remaining warranty
My Service Adviser brought me back in the shop and showed me this today. C7 Z51 M7 Trans. I don't know the "circumstances" that lead to this, but HOLY COW!! The valves and a lot of the head pieces. He did say the peak rev's were in the 8,000 range.
are in the bottom of the oil pan.
Received 8,929 Likes
Definitely not covered by the warranty with an over rev like that. Must have downshifted incorrectly or downshifted when trying to upshift.
Bill
Bill
I was told they are covering it under warranty. Good for him. I'm glad I found a dealer that doesn't always look for reasons to charge loyal customers. They said they can see peak rev value, but not the duration. It won't be long before the system will record all kinds of events like a black box recorder so they can see all sorts of parameters such as gear, speed, etc.
rsvette12 (12-21-2017)
I also agree this was probably an ill-advised or botched downshift. The rev limiter protects the engine going up, but not from an over-rev on a downshift.
Wow - can they actually track at a point in time what the max RPM was? If so, I agree it could only be a botched downshift - or a tuned car that for some reason removed the rev limiter.
Maxie2U (12-24-2017)
Peak HP and torque happens and begins to drop well before redline, so no reason to go there.
The only way stop an over-rev on a downshift would be to put an electronic block, a la CAGS, disallowing downshifts at certain speeds and rev ranges. And, of course, everyone would be immediately looking for a way to defeat it.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Maybe not defeat it if they once blow their engine and it's NOT covered. Like this one probably won't be. Maybe.
Quite frankly, it takes a pretty bad driver to do something that ridiculous. The shift gates essentially block such radical downshifts, unless somebody purposely forces it.
Received 2,225 Likes
If I had done that I wouldn't expect it to be covered under warranty. It was operator error.
madrob2020 (12-24-2017)
Walt White Coupe (12-21-2017)
