new leather skin on my 1986 steering wheel
Old 12-27-2017, 03:26 PM
86vetted
86vetted's Avatar
Default new leather skin on my 1986 steering wheel
Hello All:
I’m putting a new leather skin on my 1986 steering wheel. The original leather was cracked, rotten and nasty looking. Does any body know what the sticky layer is between the rubber over molded wheel and the leather skin is? I think it is a sprayed on layer to keep the leather from moving around. Any insight would be greatly appreciated.
Thanks Ed A
Old 12-28-2017, 12:39 PM
VikingTrad3r
Oil Producer
Support Corvetteforum!
VikingTrad3r's Avatar
Received 2,262 Likes on 1,446 Posts
Interesting project. Where is the replacement leather skin sourced from? I have a wheel id like to so the same with.
As for glue, ive seen oldschool yellow contact cement used in upholstery and i have used 3m spray 90 as a permanent and pretty much instant spray adhesive bond.
Im not familiar with how the skin is positioned around the wheel as to whether or not using a quick/instant adhesive would be smart ir not.
Old 12-28-2017, 09:54 PM
HAD2HAV2
HAD2HAV2's Avatar
If the leather wrap is sewn on then the leather will not slip.
Old 12-29-2017, 12:40 PM
ColaBear
ColaBear's Avatar
2018 C1 of Year Finalis4
HAD2HAV2 (12-29-2017)
Old 12-30-2017, 11:56 AM
86vetted
86vetted's Avatar
Default Here are some before pics
Old 12-30-2017, 02:39 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Do you have a picture of the new skin? As mentioned before, this is sewn onto the steering wheel. Might need an upholsterer to do this.
Old 12-30-2017, 08:48 PM
86vetted
86vetted's Avatar
Default The New Skin
It fits very snug on the outside of the wheel. Stitching is pretty straight forward however after I removed the tar like coating, I will be using E6000 to bond the skin to the wheel.
Ed A
Old 02-04-2018, 10:41 AM
86vetted
86vetted's Avatar
Well it’s finished! It took a lot longer than anticipated but well worth it. Having never worked with leather before, it was a bit of a learning experience.
Old 02-04-2018, 11:07 AM
belairbrian
belairbrian's Avatar
Well it certainly came out nice.
A couple of post mentioned it being sewn to the wheel. Is it actually sewn to the wheel or laced to itself?
Old 02-04-2018, 11:13 AM
VikingTrad3r
Oil Producer
things usually do take longer to get them looking perfect which yours does.
where....did you source the cover? i need to do mine it looks like your old wheel.
Old 02-04-2018, 11:18 AM
billschroeder5842
Zen Vet Master Level VII
billschroeder5842's Avatar
Received 1,140 Likes on 845 Posts
Well done- that looks great.
Old 02-04-2018, 03:00 PM
JungleCat
JungleCat's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Nicely done.
Old 02-04-2018, 09:34 PM
383vett
383vett's Avatar
good job!
Old 02-04-2018, 11:39 PM
zachaeous
zachaeous's Avatar
Great job!
Old 02-05-2018, 12:00 AM
RUU
RUU's Avatar
Old 02-06-2018, 08:36 AM
Renfield
Renfield's Avatar
Beautiful job. Isn't the center section leather as well?
Old 02-06-2018, 01:17 PM
ghoastrider1
ghoastrider1's Avatar
That does look very nice.
To new leather skin on my 1986 steering wheel
Old 02-06-2018, 10:26 PM
MRPVette
MRPVette's Avatar
Looks great.
Old 02-06-2018, 10:35 PM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
Makes me want to take up sewing ...
Old 02-08-2018, 08:12 PM
rblakeney
rblakeney's Avatar
Did the needle and thread come with the kit? What's the source?
I've looked at it several times and that's a good job.
Quick Reply: new leather skin on my 1986 steering wheel
